Help with KOER.
Old Mar 29, 2020 | 07:50 AM
Aapple416's Avatar
Aapple416
Help with KOER.
I have a 95 f150 4x4. With a 5.0 an E4od f
when I try an run a KOER the check engine light flash 4 times then once. It will rev up for about 45secs then idles down but starts popping sounding like a backfire from the exhaust before the check engine light even flash for you to hit the throttle.
Any help would be awesome
Old Mar 29, 2020 | 08:53 AM
jas88's Avatar
jas88
Any code you would get on a 1995 should have 3 digits.
Old Mar 29, 2020 | 11:10 AM
subford's Avatar
subford
The check engine light (MIL) flashing 4 times just says you have a 8 cyl engine.
Engine Identification Codes (ID Codes)
Engine ID codes are issued at the beginning of the Engine Running Self-Test and are one-digit numbers represented by the number of pulses sent out. For gasoline engines, the engine ID code is equal to one-half the number of engine cylinders (i.e. 2 pulses = 4 cylinders). These codes are used to verify the proper PCM is installed and that the Self-Test has been entered.
Then the one flash is the goose engine now flash.
The popping could be a lean fuel mix. Maybe low fuel pressure.
Aapple416
Mar 30, 2020 02:10 PM
Swantastik
Escape & Escape Hybrid
Nov 10, 2015 10:44 PM
jimdisaster
Aug 28, 2006 12:27 PM
steve340
Jun 3, 2006 10:46 PM
ditchen
Jul 13, 2005 09:34 AM
