Broken Water Pump Bolt
Old Apr 2, 2020 | 01:33 PM
mannermauler's Avatar
mannermauler
Hey folks, I've been replacing the water pump on my 95 F250, and discovered one of the bolts was missing. My dad and I tried a bolt extractor, but it's not budging. What is the risk of it leaking? We have all the other bolts and we really need this truck running. If you refer to this post, it's the G bolt.
Old Apr 2, 2020 | 03:15 PM
GNR22's Avatar
GNR22
You might get lucky and avoid a leak. Or you might reassemble the whole motor and discover that you have a large leak and you need to tear the front of the motor apart. I think that if Ford thought you didn't need that extra bolt to seal the pump, they'd have omitted it and saved 3 cents per motor. Just drill it out and get it over with. It'll be much less of a pain than discovering a leak later.
Old Apr 3, 2020 | 10:06 PM
baddad457's Avatar
baddad457
That's one of the bolts that are open to the coolant passage behind it. Instead of an extractor, if you have a welding machine, weld a 9/16 nut (3/8 nut) over the broken end of the bolt, filling the center of the nut with weld. When the weld cools to grey, unscrew the bolt. This works 90% of the time. If it doesn't work the 1st time, try it again.
mannermauler
13
Mar 29, 2020 09:30 PM
jben04
Nov 27, 2017 07:08 PM
86scotty
Jun 16, 2015 06:26 PM
xjpilot
15
Mar 11, 2012 10:57 PM
f-250diesel
Dec 31, 2010 09:01 AM
