V10 Excursion DT360 swap
Old Mar 26, 2020 | 08:04 AM
Creekside48's Avatar
Creekside48
Ok I bought a 2000 Excursion with a V10 with the original plan of a Cummins swap, although the more I look at the DT360 sitting in the corner of my garage, I’m thinking it sounds like a different option. I have found threads online where people have done it, but not really what all is really involved in making it fit. I would like to keep the stock trans if possible, possibly 5r110. I’m not planing on building big power. Just something different that gets better than 8-10mpg. Has anyone here done that swap? Or know how much more involved than the Cummins swap would be?
Old Mar 26, 2020 | 09:42 AM
merc460's Avatar
merc460
I've done it and it all depends on your fab skills , as there is some fab work to do. I don't think you can get an adapter for the 5R100 as the one I got was for the 4R100 from the only guy that make them , but I could be wrong.
It would be easier to swap a cummins in cause everybody makes kits for that swap. I did my swap in a 97 F350
Old Mar 26, 2020 | 11:44 AM
Creekside48
I am capable of fabrication. I would rather not cut into my firewall though
Old Mar 26, 2020 | 12:17 PM
merc460's Avatar
merc460
Not sure about the SD fire wall , the OBS fire wall need to be moved back
Old Mar 26, 2020 | 09:34 PM
Creekside48
  1. thanks. I’ve seen where guys have swapped the SD but not what all they had to do. I really like the idea of the DT being it isn’t as common as the Cummins and already having the engine vs buying another one is a plus. What for mileage are you getting out of yours?
Old Mar 28, 2020 | 09:28 PM
Creekside48
I’m looking at adapters for the Transmision, I would rather not have to buy another trans at the moment but would a gas 4r100 hold up to a dt360 or should I upgrade to a 5r100 or diesel 4r100? Other than the obvious bolt pattern difference is there any internal differences from gas to diesel 4r100s?
Old Mar 29, 2020 | 09:18 AM
merc460's Avatar
merc460
I don't measure fuel mileage, as it is what it is. When its empty I fill it. I am not sure on the trans internal differences. The adapter I bought was for a Diesel 4R100 so that's what I used.
Old Feb 22, 2022 | 01:33 AM
Big Block Enthusiast's Avatar
Trailering
Was wondering if your engine had a built-in power steering pump or did you have to add a belt-driven one? Also, where did you get that valve cover?
Thanks
Last edited by Big Block Enthusiast; Feb 26, 2022 at 02:16 PM. Reason: Grammar mistakes
Danben111
Engine Swaps
Feb 24, 2020 01:39 PM
wicker63
Oct 24, 2016 06:54 PM
wicker63
Oct 24, 2016 11:32 AM
jolly774
Engine Swaps
Jun 7, 2007 07:24 PM
powerstroker27
Nov 22, 2005 12:00 PM
