Understanding alien abduction
Old Jan 5, 2023 | 06:41 AM
  #541
V10 Harley Hugger's Avatar
V10 Harley Hugger
It's from a 360 viewpoint that we'll all move forward.
Old Jan 5, 2023 | 10:36 AM
  #542
Papa Tiger's Avatar
Papa Tiger
Having the best view may be an inherited trait over the millennia, maybe the lil Alien wants to grow taller ? ........
Old Jan 5, 2023 | 01:52 PM
  #543
Papa Tiger's Avatar
Papa Tiger
Well its one hell of a Lightening Rod ! .....I bet a good tail wind makes some real interesting flight time.
Old Jan 5, 2023 | 03:19 PM
  #544
Papa Tiger's Avatar
Papa Tiger
The truth is out there somewhere or where! Probes, ugh oh no, oh boy!...........
The UFO Experience: The Truth is Out There, open at AZ Boardwalk | Watch (msn.com)
Old Jan 5, 2023 | 04:21 PM
  #545
V10 Harley Hugger
That's what they said...
Meanwhile...
Old Jan 5, 2023 | 04:28 PM
  #546
Papa Tiger's Avatar
Papa Tiger
What can you add to a Comedy with out screwing it up ? Dang overacting Id-i-juts ! .....
Just ask your imagination what will happen if you are traveling the speed of light and
Billions of Photons / Particle / Waves are striking you from every direction imaginable.
Well imagine your proximity most likely is History of some sort, is or if someone is watching the thing.....
Imagine if, Yep you're a gonna end up as something else than what you started out as & as your imagination says, " thas a no brainer!"
Understanding that Wave / particles are traveling in most every direction constantly
through all the universe and you are so very easily just on your vacation trip to End River Falls,
so to explain it to all the average imaginations of persons, you are, gonna get smacked sooner than later &
most likely a whole bunch, like in a random duck shoot & that's so, well; is easy to imagine!
Imagine that You only have the energy of the wave Particle starting out that day and you are and have only that out here!
It's sort of a no brainer why you turn into the most common thing in the universe after getting busted around like a wrestler!
Hydrogen, it is the easiest to make. Imagine your a blob of Hydrogen gas now slamming into more of the stuff left, right, up & down!
Spinning like a cart wheel, What do you do? hell you don't even know the time. Well you get all heated up, its sex to ya &
attracting more hot bods and getting really heated up, it's a kiss me no brainer to imagine & why?
Cause you are super energetic and you want more space stuff, beginning Space Time, happening again and again.
By now we all can use our imagination, we are most likely just as aggravated as the molecules of Hydrogen all clumped together in a soup.
Imagine that no one can actually watch it so it doesn't matter if a ton of time passes or not or even if time exists for a long long passage of wave / particles of imaginary images. So by stepping away from the looking glass and imagining stuff does it happen? You know a Bacteria knows a White Cell is after it and it can't see crap, neither can the White cell but they sense, imagine each other and the bacteria will run like hell to escape the white cell trying to surround / ingulf / digest it. Which has the better imagination ? Is imagination responsible for the development of eyes. Or was it photons on the skin. Imagine it was both, the warmth feeling on the skin and imagination. I noticed the other day that Intel has gone above the i5 / i7/ i9 / i16 to the i24... Can I imagine a day when I won't have to buy one of these? Watch a fish suspended in the water all afternoon, nothing to do, not hungry, why does it point toward the sun all afternoon is it dreaming about walking out ?
Old Jan 8, 2023 | 01:21 AM
  #547
Papa Tiger's Avatar
Papa Tiger
Maybe understanding Alien travel is best explained with potential of energy thoughts. Energy needs heat. Enough heat and stuff gets excited and jumps someplace else. So the Constant factor is cold. The Colder it is the less energy. Sure Thas a no brainer. So, we can look at the Center of the Milky Way, Lots of hyper active energy there, some escaping outward and a lot getting swallowed up into an intensely cold region called the super massive black hole. Now the natural thing for energy to do is blast away toward an area that is needing it. Much like a battery has a Positive pole with lots of Electrons and a Negative pole dreaming of having some electrons. Now this gets complicated because the Positive post is actually where the Electrons are stored and their negatively charged but thas really a no brainer. All it needs is a completed path of conduction. But without a load the thing will blow up as in a Short circuit. Put a load such as a light bulb or a motor and the current will be stabilized and keep going until the positive electron area is depleted and the negative area has done its stuff also with the loss of power caused by resistance of the medium the power passed thru. So, are you following the theory. As the power is Created also is reduced, it doesn't exactly disappear, it just changes like resistance to it, its flow be it gravity, banging into stuff, wrecks, etc.... Now imagine an alien with a lot of power in his tank. Does he really want to waste a lot of it coming to visit a really low power planet with a negative plate. Most likely not. Imagine it, would you give a dam about us. Would you just keep collecting energy, power for your bucket list? Again intense cold is the Constant Culprit, just like you going out shivering, not being able to pry open your frozen door on you frozen F150, getting it started with the Key Fob remote start 3 or 4 times while waiting 1/2 hour for it to get the energy to warm up and unlock the doors. Thas nothing like the Cold of Space. Maybe the end all imagination is just be happy. Out there in deep space is a purr - fact - Hell. Imagine highly intelligent life forms knowing they have to collect all the energy they can to survive, Solar Cells atop everything, only a few areas where they can walk open spaces on ground, seeing a stream flow & some frog like creature Croke or a fish like thing splash, or sunlight actually warming their rather wrinkled skin. They not having unlimited fossil fuels, burned millions of years earlier, fuels, Fusion all used up & to learn the end all, a no brainer. Their Star dying of old age and their cool, they know they did good. also a no brainer. All those Civilizations learn how to communicate with each other eventually. Consciousness is a really cool invention of imagination isn't it. Planning to travel 50,000 light years, well; it the intense cold will absorb so much heat, there will be no energy left. Go outside, make a snowball, open the frozen Nitrogen and drop it in, watch what happens, and thats not the intense cold of Deep space. Imagine frozen so cold atoms quit moving! Most likely Voyager is experiencing the Cold of Deep space. Voyager 2 will most likely do the same.
Old Jan 8, 2023 | 01:06 PM
  #548
speakerfritz's Avatar
speakerfritz
If earth is the prison planet, then the aliens must be the wardens.
Old Jan 8, 2023 | 03:12 PM
  #549
Papa Tiger's Avatar
Papa Tiger
There is still hope for us! ......
Old Jan 8, 2023 | 08:22 PM
  #550
V10 Harley Hugger
I dunno Pap, when there's all these different (religious) groups killin each other since we been wiping our ***,
just because one prays to a different God or has different beliefs? If I was a alien I'd just soon slide on by.
Old Jan 9, 2023 | 10:55 AM
  #551
Papa Tiger's Avatar
Papa Tiger
↑ The Conservation of Energy plan! ... If I was at my base behind the Moon, well dug in, getting satellite feed 24/7's of Earth and listening to the Crap
Well; I'd pump the tanks back full of Warm and leave 2! ...Leaving a Traffic sign out there in deep space warning travelers ! ...→ ↔ nothing over there!
40 years"if" Mork & Mindy, the Flintstones,Twitter, Facebook & Spock Logic, Warf and Klingon indifference + Deep Space Nine. Ferengi, The Lobes/The Lobes, Pain/ Pain! Enough, CHARGE the happy chips BOTU, we out of here
Yep space travel is simple, We create a bubble of Warm, point it where we want to go and poof !
Old Jan 9, 2023 | 11:37 AM
  #552
V10 Harley Hugger
Old Jan 9, 2023 | 01:43 PM
  #553
Papa Tiger's Avatar
Papa Tiger
Star Trek Officially Gives Scotty the Legacy He Deserves (msn.com)
It was just going too "Far Far Away"... We out 0 there! ...
Old Jan 10, 2023 | 01:52 PM
  #554
Papa Tiger's Avatar
Papa Tiger
Understanding Human behaviors become a perplexing Conundrum.
The Blonde, a brunette and a redhead
are stuck on a deserted island together.
The island is 20 miles from the nearest inhabited island.
They decide to try to swim there. The redhead makes it 10 miles,
is exhausted, gives up, and drowns. The brunette makes it 15 miles
before she's too tired to go any farther and drowns.
The blonde gets 19 miles away from the deserted island,
decides she's too tired to go any farther and
swims back to the deserted island. The Alien Observer
smacks what's his Forehead!
Old Jan 10, 2023 | 02:00 PM
  #555
speakerfritz
