Butt welds for patch panels
Old Aug 30, 2020 | 11:12 PM
  #61
MP&C's Avatar
MP&C
Playing catch-up here, the inside of the crease was blocked using tape to keep the center line sharp, then brace welded in place and some epoxy touch ups done..
With the touch ups blocked, we're ready for some Epoxy/sealer, some PPG ESSS base, and my first time spraying SPI Universal... WooHoo! love this clear!!
These Ford truck hoods can be a pain to get good paint coverage inside the nose.. So a couple pieces of TIG wire from our rack to the hood brackets hold it up in the air so we can get into the nose with the spray gun..
Old Aug 30, 2020 | 11:25 PM
  #62
Moe Craig's Avatar
Moe Craig
Wow... nice work on the hood!
Old Aug 31, 2020 | 05:57 AM
  #63
Justboy's Avatar
Justboy
Spraying the inside of a panel is a right PITA but most shops would never even know that because they don't bother to do it. Amazing attention to detail.
Tried spraying the inside of front fenders yesterday and there really must be a better way of getting into places the gun can't reach like a right angled nozzle?
Old Aug 31, 2020 | 07:38 AM
  #64
schoo's Avatar
schoo
I want to thank you for the time you put into threads like these it is very helpful for us beginners
Old Sep 1, 2020 | 11:30 PM
  #65
MP&C's Avatar
MP&C
Thanks gents!
Thought I'd do a progression of pictures to show the carnage we started with on the hood brace to where it was painted this past weekend....
Note the wings left adjacent to the weld to act as heat sinks and prevent the edge from burning back...
No Body filler, just epoxy primer, basecoat, and clearcoat. Looks almost factory!!
Old Sep 17, 2020 | 06:52 AM
  #66
MP&C's Avatar
MP&C
So every time we place the hood on my folding stand, the hood skin deflects upward at those pressure points (corners). Which means that won't work for blocking out the hood. So lets' use the same supports that the hood uses and make a blocking "stand".
Large 5/8" bolt through the hood latch hole for supporting the nose...
And going through our scrap inventory, here's some tubing we used for the back end, bolted into the hinge support. The extra "feet" help to stabilize it so the sanding effort won't try and flop it over...
With that done, all our open holes are taped over and the entire bottom side masked off to protect the inside finish..
A bit of Evercoat 416 to address some lows, and 3 coats of SPI epoxy for the next round of blocking on the outside.
Blocking...
Some booth clean up and fresh masking on the table, hood pre-cleaned and tacked.....
Sealed with SPI Epoxy thinned about 10%
Fleet paint that was used originally on the truck, supplied by owner. Orange peel in a can..
2 coats of color, 2 coats of SPI Universal Clear...
Old Sep 17, 2020 | 10:26 PM
  #67
Scotty's 52 F3's Avatar
Scotty's 52 F3
Thanks for taking the time to document all this amazing work. Helps guys like me with zero body and paint experience.
Old Sep 18, 2020 | 12:27 AM
  #68
52 Merc's Avatar
52 Merc
Indeed. Even those of us with experience are duly impressed. It's good to see others with such a high level of detail. I really enjoy following this build.
Old Sep 18, 2020 | 10:02 AM
  #69
allout5151's Avatar
allout5151
Brilliant idea on making a stand for the hood. I am going to copy your idea when time comes to work on my hood.
Old Sep 18, 2020 | 11:06 AM
  #70
MP&C's Avatar
MP&C
Thanks for the comments and for checking out our work!!
With the one "pivot point" it may tend to want to fold over, hence the fore and aft feet welded on... Helps to keep things stable during the sanding effort...
Old Sep 18, 2020 | 04:36 PM
  #71
allout5151's Avatar
allout5151
Had some old scrap laying around. Its not pretty but it is stable for sanding. Thanks for the design and all the tips throughout this thread. Cheers.
Old Sep 21, 2020 | 06:00 AM
  #72
MP&C's Avatar
MP&C
Well done on your stand!!
This past Friday night we cut and buffed the F7 hood to get rid of some dust nibs, and Saturday morning Jared and I started to reassemble the hood. The horn wiring had some dry and cracking insulation sleeving, so it was replaced as well.
John stopped by mid morning and we got all the parts put back together and adjusted. Looks much better with the hood back on, John has been driving without one for a couple months.
All ready for the Tri-state Antique Truck Show this week in Clear Brook VA..
Old Sep 23, 2020 | 10:54 PM
  #73
MP&C's Avatar
MP&C
John got the truck loaded up today, ready for departing tomorrow for the Tri-state Antique Truck Show at the Frederick County Fairgrounds in Clear Brook, VA. Hopefully if any of you guys see this at the show you won't be able to tell what I've done.. I may have to take a ride on Friday myself and check out the show......
Old Sep 24, 2020 | 03:57 AM
  #74
seaves46's Avatar
seaves46
This thread was started almost 6 months ago , did it take that long to do the repairs ???
Old Sep 24, 2020 | 04:16 AM
  #75
MP&C's Avatar
MP&C
We are a part time shop and this hood repair was being done in between other projects and the distraction of travel for the day job, so yes.
