Butt welds for patch panels
Old Mar 22, 2020 | 08:24 PM
MP&C's Avatar
MP&C
The tack welds are merely to keep the panels aligned for welding. Yes, it does warp up when you weld as the weld is shrinking. When you get done, planish the weld to give it some stretch and the warping goes away.
Old Mar 23, 2020 | 07:29 AM
Greg Rogers's Avatar
Greg Rogers
You guys are obviously metal working Gurus! I envy your skills and thanks for posting. I also have seen some of your great work on the HAMB. Carry on!!
Old Mar 27, 2020 | 06:46 AM
MP&C's Avatar
MP&C
Thanks Greg!
Now to fine tune our dies for the hood brace. Looking at our original profile template, the first upsweep (red arrow) and second upsweep (yellow arrow) are both nearly vertical as compared to the opposite side.
Our first test run shows the first upsweep spread too wide, not enough vertical...
Looking at the die that was made, a bit too much material was removed such that this vertical feature was lost...
So a new die was made for the top, this time out of aluminum. The phenolic is somewhat easy to cut out but does have challenges in making crisp bend details, so lets see if the aluminum helps out..
Next run, this time we'll do two panels in case they work... First pass to draw the metal into the center rib...
This is about 8 passes, each progressively deeper. The circle fixture to the right in the picture (white base) is used as a back stop to keep our rib centered.
This is about 9/16 of depth, so quite a bit of draw.. Next, the new top die is added and goes through the same 8 progressive passes.. Note in the next picture the vertical upsweeps are both nearly vertical. Success!
Matching up to the original, this looks like the right replacement.
video version:
Old Mar 28, 2020 | 11:22 AM
WNDOPDLR's Avatar
WNDOPDLR
Smile
WOW! I have learned much from your pics and captions...............mostly I have learned how inferior my metal working skills are -), Thanks for posting and I will continue to learn.
Old Mar 28, 2020 | 12:04 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
You make it look so easy. Great work! Thanks for posting.
Old Mar 28, 2020 | 05:31 PM
MP&C's Avatar
MP&C
Thanks for the comments guys!
Progress on the hood, the bead details in the brace are offset on the ends to match the hood opening flange. So we use a Vernier protractor to find the angle, and transfer that to our panel. This is where the transition of the taper starts..
Once tapered, the excess is removed from the bottom side and the outer seams TIG welded in place.
A piece of round stock has a radius added to serve as a hammer form for the beads. They are hammered around and excess removed from the back side..
A piece of 16 gauge cold rolled steel is trimmed to fit and TIG welded in place.
Welds dressed and media blasted..
The bend line is transposed from the original. As this bend is slightly convex, it was started using a tipping wheel on the bead roller to a 45* angle, and then finished on the mag brake.
A reminder of the carnage we are repairing:
A profile template is made prior to cutting out the old....
Old Mar 28, 2020 | 10:29 PM
Red60's Avatar
Red60
This is neat to watch and learn even if I’m likely too chicken to try it. Still learning pointers and techniques. Excellent post! Thanks and keep them going!
BMC
Old Mar 28, 2020 | 11:41 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Watchin and learnin. Thanks for posting.
Old Mar 29, 2020 | 09:59 AM
EBEAR's Avatar
EBEAR
Fantastic work made possible with the great " toys " you have . It is interesting and helpful for everyone to have an idea of how much goes into these repairs regardless of their own skills .Thanks for sharing . P.S. I'm quite glad that I'm not on the receiving end of bill for that little ( 20 + hour ? ) repair . lol
Old Mar 31, 2020 | 10:34 PM
MP&C's Avatar
MP&C
Thanks for the comments and following along with our progress!
Time to get the hood brace end welded in place. The overall measurement had been taken prior to cutting off the old one, down to the 14 gauge outer plate as a reference. So the new end is trimmed to match this dimension, then held in place with rare earth magnets. The center (inside) rib is aligned and tacked using the TIG....
Working outward, the panel surfaces are aligned and tacked as we go. Note the "batwings" left on the outside of the new brace end (yellow arrows). This will act as a heat sink when we make the outer tacks. Had these been trimmed to match prior to welding, the edge will have a tendency to burn back from the heat.
The entire seam is TIG welded and then our batwings are trimmed using offset snips, then welds dressed..
One down......
Old Apr 1, 2020 | 08:39 AM
Greg Rogers
Thanks so much for the "batwing" tip. That will really help, I will use that!
Old Apr 1, 2020 | 09:22 AM
pweng1's Avatar
pweng1
I am curious as to what machines you have in your shop and how you come to learn to use them.I have been adding to my collection but i dont think i have enough time to learn to master them all. My sons have lost most interest so I afraid It will end when im gone.
Old Apr 1, 2020 | 11:18 AM
  #28
MP&C's Avatar
MP&C
The ribs were added using a Lennox TE250 Metl-Master (Pullmax type machine). Other eqpt includes Baileigh MH19, Pexto 5212 shear, Diacro 2' hand powered press brakes, 4' magnetic brake, Fasti-Werks Swaging machine (bead roller) , etc, etc. For the most part self taught other than a few videos and some metalshaping workshops.
I see you are in MD, when this plague stuff subsides, stop on by for a shop visit, I am in Leonardtown.
Old Apr 1, 2020 | 11:29 AM
  #29
Old F1's Avatar
Old F1
X 2 (.. as long as I remember to ! )
Old Apr 2, 2020 | 04:35 PM
  #30
Marten's Avatar
Marten
So how do you prevent things from shrinking when you weld? Or adjust them afterwards. That is my biggest challange.
