front brake hose
Old Mar 17, 2020 | 03:07 PM
Kerby76's Avatar
Kerby76
front brake hose
I put a 4" suspension lift on my 1977.5 (low boy) F250. I need new front brake hoses. Here is my question: do I need to buy extended hoses? Mine have some slack but if OEM length ones have worked well for others then that is what I will buy. The Sky Jacker ones are double the price of stock style. I don't do heavy off -roading just hunting camping with the truck.
Old Mar 17, 2020 | 04:52 PM
fordguy2100's Avatar
fordguy2100
They might work on flat level ground, but how much slack do you have? if you hit a good sized pot hole, or when hunting hit a rut that drops one side down pretty far... will you have enough line to not pop off? My knee jerk reaction would be if you added 4" between the axle and the body (where the soft line goes between) then you would want to add 4" of line as well. Might not be absolutely necessary but it would be a good peace of mind nonetheless. Im sure some other guys with a low boy and a lift will be along soon to give you more feedback.
Old Mar 17, 2020 | 06:16 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes you do. I have a 4" Rough Country lift on my 78 Lowboy F250 and I did flex checks before it rolled out the shop. Just get the longer ones. Skyjacker has steel braided, bolt, bleed and go ones for the front and the rear. https://skyjacker.com/shop/category/brake-line/
Do not cheap out after you put the lift on, 1st time you flex past the OEM slack and rip a connection you will wish you went and got longer ones.
You DID get a drop pitman arm, adjustable steering link and longer shocks right? Might as well do it 100% right. I am not saying nothing about stacking the rear blocks.
Old Mar 17, 2020 | 07:09 PM
Kerby76's Avatar
Kerby76
Yes, you are right i did all those things so why skimp now. I just ordered those Skyjacker hoses. thanks
Old Mar 17, 2020 | 08:06 PM
mark a.'s Avatar
mark a.
Or you could just move the hose brackets to the bottom of the frame and continue on with the stock hoses.
Chris Popanz
Jan 24, 2015 10:40 PM
$Simpleman76
Aug 12, 2007 08:02 PM
paragod
Mar 12, 2005 07:37 PM
STechsan
1966 - 1977 Early Broncos
Oct 16, 2004 10:05 PM
