Frames
Old Mar 17, 2020 | 10:40 AM
Scott Karsten's Avatar
Scott Karsten
Frames
Is a 1988 f150 2 wheel drive frame rails the same as a 4 wheel drive frame rails
Old Mar 17, 2020 | 01:39 PM
jas88's Avatar
jas88
Yes the frames are the same. Even the F250 and F350 frames are the same as far as dimensions, but the steel is thicker.
Old Mar 19, 2020 | 05:55 AM
tjc transport's Avatar
tjc transport
i ain't rite
while the frame rails are the same size, the holes for mounting things are not the same.
and the F250-F350 frames are the same, the difference is in the suspension blocks.
Old Mar 19, 2020 | 06:16 PM
Conanski's Avatar
Conanski
No the HD truck frames are taller as well as being made from a heavier gauge, it's part of the reason those trucks sit higher.
Old Mar 20, 2020 | 06:55 AM
tjc transport
i ain't rite
the 350 sits higher because the 250 uses 2 inch rear blocks and the 350 uses 4 inch rear blocks.
beezerboy
Sep 6, 2013 05:00 AM
Outcastz89
Oct 19, 2007 12:13 AM
primer85f150
Nov 8, 2006 03:23 PM
NorthernFord
Feb 16, 2004 11:37 AM
sportscar
Appearance & Dress-Up
Mar 25, 2003 09:17 PM
