Questions about frames...
Old Oct 18, 2007 | 11:29 PM
Outcastz89's Avatar
Outcastz89
Hey everyone,I got a question or a few.I'm building a ford costum cab short box that has a two wheel drive frame.I'm converting it to a four wheel drive.If I get a four wheel drive frame that's for a long box,can I cut down the frame to fit my short box?If I can how hard is it and is it more work than it's worth?Or should I just keep trying to find a four wheel drive frame for a short box?Thanks a lot.
Old Oct 18, 2007 | 11:36 PM
masterbeavis's Avatar
masterbeavis
seach with retsin, two mints in one. I have been pondering a similar situation, it is the safest way to make your frame (uncut) into a 4WD frame. you already have the coil buckets, find a 76-79 half ton front end and the steering, make it work. Lift it while you are at it, so your front axle wont hit the crossmember.
Old Oct 18, 2007 | 11:46 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
I think it would be a whole lot easier to have someone who is a darn good welder and knows what they are doing to shorten the long frame than it is to reinvent the wheel and put a 4x4 axle under a 2wd.
Old Oct 18, 2007 | 11:48 PM
masterbeavis
True, however which is going to cost more? Also, how many people do you know claim to be good welders, and that you trust with your families life?
Old Oct 18, 2007 | 11:49 PM
Outcastz89's Avatar
Outcastz89
Yeah,thats what I thought.I would probably end up welding in a lot of mounts for everything.
Outcastz89's Avatar
Outcastz89
It's mainly just for me though lol.But you are very correct.
Old Oct 18, 2007 | 11:50 PM
FordTrucksKickGM
It might cost something to find a good welder but you will save a lot of time and have fewer headaches.
Old Oct 19, 2007 | 12:02 AM
wetdog4x4's Avatar
wetdog4x4
Smile shorten it
shorten it.. will be easier... and i wouldnt be to worried about it not being safe.. if you ever seen some of the factory welds you would run for the hills..
Ray
Old Oct 19, 2007 | 12:13 AM
75F350's Avatar
75F350
Gonna find a "good welder" that is willing to assume the liability of welding a frame back together after it has been seperated?
Most "good welders" would not touch that with a 10 foot pole.
Guess you could back-half that, but that would require a complete cage to add structural integrity.
Tube style front crossmember and using the 2wd frame does not sound that difficult, and sounds much safer than hacking up a frame and scabbing it back together. Not so sure how clean welding a frame together would turn out regrdless of welding talent.
