Sponsored by: Real Truck
Shocks
Old Mar 24, 2020 | 08:40 PM
the beast 1's Avatar
the beast 1
The block in the picture of the rear is 4in . Factory wouldn't be that tall would it?
Old Mar 25, 2020 | 09:11 AM
Diamnd1's Avatar
Diamnd1
I have an '04, the last year of the leaf sprung front. I replaced the Rancho's with Bilstein 5100's and it does ride stiff. But I only use the truck to tow the camper with a golf cart in the bed so I needed the extra shock absorption capacity. If I daily drove it, I would probably get the Bilstein 4600 or Monroe's
Old Mar 25, 2020 | 09:19 AM
SuperDutyScaler's Avatar
SuperDutyScaler
Yes the 3.5" block is factory for the F350 and a common upgrade for the F250 trucks.
I had stock, then bilstein and then skyjacker nitro shocks on my 2004 f350. Two months ago I installed skyjacker HYDRO shocks and they are by far the best shocks I've had on this truck! Handling is the same as the more expensive nitro shocks but the ride is much smoother and softer if that's even possible on a super duty LOLOL. But honestly the hydro shocks are by far the best I've had so far
Old Jul 9, 2020 | 06:17 PM
MissileMech's Avatar
MissileMech
SuperDutyScaler, what Hydro model did you use, the Black Max or the HYDRO 7000?
Old Jul 11, 2020 | 01:56 PM
Trey's Avatar
Trey
The only issue of the preload spacer lifts is that they alter the spring rate progression as it compresses, you get more resistance earlier in the travel than the stock setup.
The solution for a plush compliant front suspension travel in these heavy trucks is replacing the spring and shock together. Taller springs with a shock specifically designed and valved for that vehicle and shock spring completey enhance these trucks handling.
I would take a hard look at the Icon products. They turned my truck into a plush offroad beast. No affiliation with Icon, just very happy with my own purchase experience and performance difference. Look for reviews on here from other posters. They are an excellent, cost effective upgrade.
Good luck!
RONMCHUGH
1983 - 2012 Ranger & B-Series
Mar 15, 2020 04:52 PM
Thomas Cottier
2009 - 2014 F150
Jun 9, 2019 03:50 PM
strokem
Apr 5, 2011 10:48 PM
TxFireman1972
Ford Truck Parts for Sale
Oct 27, 2010 09:19 PM
MeanGene1
May 5, 2007 07:18 PM
