Hopefully someone has encountered this, but all my hazard signals work, but only the rear turn signals work. All new bulbs. Is there a seperate circuit that runs turn signals and hazards?
So all 4 lights front an back flash with hazards ? But only rear flash with turn signals ? If thats the case I would lean towards corrosion up front at sockets an housings ,,weak grounds or something like that,,If the hazards work front an back but no turn signals at all then there are two flashers under dash , one for hazards one for turn signals , and the one for turn signals may be bad
OP's "About Me" profile says 1979 F150.
1974 F100/350 from serial number T80,001, 1975/79 F100/350 park and Styleside tail lamp lens/body is a one piece assembly, the plastic sockets twist into the housings.
The tail lamps and sockets are also the same as 1975/91 Econoline and 1978/79 Bronco.
I replaced one of the sockets up front because of the ground tab was corroded away. A may replace the other as well. If that doesnt work, I'll try to find their ground and clean it or replace the connection.
Start by cleaning all the grounds, battery post to engine, intake to firewall, with these trucks being so old, I did the same, and have seen great results. The grounds, I do believe for the front circuit are on the rad support, hidden under little pieces of material to hide them I guess... clean them up real good, and see if you can get some place. Good luck
