1978 - 1996 Big Bronco
Turn signal problem
Old Oct 1, 2002 | 01:48 AM
1988XLT2002's Avatar
1988XLT2002
Turn signal problem
When i turn on my turn signals they only work when i'm in motion, while stopped just shows the solid green arrow as if the bulb has gone out and the signals dont work. But when i start moving they work fine again i'm pretty stumped about this one i have no clue whats up with this.
Old Oct 1, 2002 | 02:34 AM
Pilotrick's Avatar
Pilotrick
Turn signal problem
Probably a short. Do you have a trailer wiring harness pigtail? If so check there first, a lot of times it is where the splice is or where the pigtail plugs in. Hope this helps and Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Old Oct 1, 2002 | 08:28 AM
8996EBBroncos's Avatar
8996EBBroncos
Turn signal problem
Probably have a bad bulb or your flaher may be bad. I would check those for starters.
Old Nov 12, 2002 | 07:36 PM
bronco 1996 16 year old's Avatar
Turn signal problem
BULB OR FLASHER!!!!
Old Nov 12, 2002 | 10:31 PM
steve83's Avatar
steve83
Turn signal problem
It's probably a bad ground at the taillights, or a bulb installed backward. When you say "only when stopped", you actually mean "only when the brake lights are on", right???
Old Nov 12, 2002 | 10:32 PM
yosemite's Avatar
yosemite
Turn signal problem
Mine did that and it was the flasher that goes in the fuse box. $3
Old Nov 13, 2002 | 03:10 PM
1988XLT2002
Turn signal problem
yah i fixed the problem a while just forgot to mention it. I guess while off roading my bumper caught on something and it ripped the trailer harrness connector off. So i had bare wires grouding to the bumper i saw that so i lifted them off the bumper and now everything works fine again, for a little bit i was freaking out because i thought i had a bad short somewhere. But thanks for your info you guys come in handy.
Old Nov 13, 2002 | 06:22 PM
Goodsath's Avatar
Goodsath
Post Turn signal problem
drrider100
Apr 3, 2017 11:32 AM
Lantzmann
Sep 27, 2016 10:13 PM
markparvin
Aug 2, 2016 05:16 PM
Bradley Ripley
Feb 22, 2016 10:51 PM
AADAD
Jul 30, 2015 07:26 AM
