C6 E4OD Swap
Old Mar 12, 2020 | 11:20 PM
75 Camper Special's Avatar
75 Camper Special
C6 E4OD Swap
I'm sure this is on her somewhere but i can't seem to find the information. I have a 77 F150 Extended cab long box 2wd with a 460 that has blown up. I have access to a 93 fuel injected 460 with an E40D and was wondering if the transmission will fit without any modifications (besides the crossmember mount) and also if there is much involved with adding the electrical side of the engine and transmission.
Thanks in advance for the advice
Old Mar 13, 2020 | 12:41 PM
JP3's Avatar
JP3
E4OD is all electronic so you would need a transmission controller like a Baugmann or maybe a controller from a diesel pickup.
The trans is longer, and you'd need to come up with a way to make the column shifter work.
We use an aftermarket shifter but also used the entire efi engine & trans.
Good pics:
https://www.hotrod.com/articles/1105...smission-swap/
Old Mar 13, 2020 | 09:47 PM
75 Camper Special
That is a great article thank you. I have a complete donor truck that i can use the harnesses and computer from so hopefully it should be a relatively painless conversion. The truck it is coming out of is 4x4 but with a solid front axle from a SD so for now i will install the t-case and when i find the remaining parts i can add the front diff and axles.
Number4
Feb 13, 2019 03:01 PM
dwrestle
Apr 28, 2014 11:51 PM
NavyGuy2007
May 28, 2012 08:18 PM
jimbbski
Mar 13, 2011 11:36 PM
fordtrucksforever
Jun 9, 2007 02:27 AM
