1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
05 Navigator Dimmer Switch
Old 01-20-2016, 09:52 PM
orange57's Avatar
orange57
orange57 is offline
Hey guys,
Another one for ya. The dimmer switch does nothing for any of the dash lights during the day. And everything is at the dimmest setting, so it makes the radio screen and odometer hard to read. It did make adjustments at night when the headlights kick on. Could this be an issue with the switch? Anyone else experience this? It does turn the overhead lights on when flipped all the way up.
Thank you,
matt
Old 01-21-2016, 10:19 PM
orange57's Avatar
orange57
orange57 is offline
no one, huh
Old 01-21-2016, 11:10 PM
Skauber's Avatar
Skauber
Skauber is offline
So if you turn the headlights on, the dimmer switch works normally?
Old 01-21-2016, 11:24 PM
orange57's Avatar
orange57
orange57 is offline
The headlights come on automatically, I should check if I manually turn them on. But yes, it the lights are on, the dimmer wheel does its job. Tonight, I turned the headlight switch to off, and again no control over the dimming.
Old 01-21-2016, 11:32 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
The dimmer switch is only functional when the headlights are on.
Edit, the dash will have no backlighting with the headlights off but the Digital display lights should be at full brightness, Radio and odometer for an example.
Old 01-21-2016, 11:45 PM
Skauber's Avatar
Skauber
Skauber is offline
Correct, all dashboard lights and lights in switches and so on should be OFF when the headlights are off, regardless if they're in Auto and off or in the Off position. If the Auto feature turns the headlights ON, or if you move the switch to turn on parking lights or headlights, the dashboard lights and switch lights should turn on. As said above, displays such as the Message center, radio display and any other similar indicators should have full brightness when headlights are off.
Old 01-22-2016, 03:48 AM
orange57's Avatar
orange57
orange57 is offline
Good to know, thank you for the replirs. Definitely not full brightness with the headlights off right now. I can barely see the odometer and NAV screen in daylight. The odometer isn't a huge deal, but not would be nice to see buttons on the nav. Any suggestions on what to look for?
Old 01-22-2016, 11:18 PM
twigsV10's Avatar
twigsV10
twigsV10 is offline
With the headlights on in the daytime and the dimmer set all the way bright can you see the odometer or radio vs off?
Edit, personally the first thing I would check is fuses, might not be the problem but cheap and easy.
Old 01-22-2016, 11:37 PM
orange57's Avatar
orange57
orange57 is offline
I will take a look at the fuses tomorrow. I do not believe there was a difference in the brightness during the day with the headlights on. I will double check tomorrow and post back here with the results.
SmallBlockV8
10-13-2009 08:29 AM
1957F100
07-25-2007 03:48 AM
Jeff396
04-05-2007 07:55 AM
al_huryn
1978 - 1996 Big Bronco
03-14-2007 07:51 PM
Quick Reply: 05 Navigator Dimmer Switch
