Efuel PSI issue
Old Mar 10, 2020 | 04:03 PM
Blueballs_7.3's Avatar
Blueballs_7.3
Efuel PSI issue
ok, so im having a problem now with psi. With the key on engine off my psi is reading almost 100. With it started and idling it bounces around 60-65. What could cause this? I had a problem a few weeks ago with low psi which was due to a clogged filter.
Old Mar 10, 2020 | 07:06 PM
97-psd's Avatar
97-psd
I don’t know how yours is plumbed, but mine shows a steady 62 psi with the ignition on and with it idling. 60-65 idling is fine. 100psi while running would be too much
Old Mar 11, 2020 | 08:25 AM
Edgethis's Avatar
Edgethis
Do you have a regulator?
Old Mar 11, 2020 | 08:31 AM
Blueballs_7.3
yes, it uses the stock international spring and plunger
Old Mar 11, 2020 | 09:52 AM
BuddyBarnes's Avatar
BuddyBarnes
What kind of gauge are you using to get the psi #'s ? I had to find your other post to find out what system you have.
Old Mar 11, 2020 | 10:11 AM
Blueballs_7.3
its a 0-160 psi glycerin filled threaded directly to the regulator block
Walleye Hunter
May 8, 2017 09:10 PM
jbulson
Modular V8 (4.6L, 5.4L)
Jul 9, 2016 10:42 AM
GDAWG 2012XLT
6.7L Power Stroke Diesel
Feb 3, 2012 11:25 PM
caseydudem
Apr 30, 2009 02:11 AM
79_250RangerLariat
Mar 12, 2008 05:05 AM
