Boost PSI ?
Old Feb 3, 2012 | 10:40 AM
GDAWG 2012XLT's Avatar
GDAWG 2012XLT
Boost PSI ?
Hay all what kind of boost psi are you getting on your truck. I am getting 20 psi. This just seems a little low. My 7.3L use to get about 23 stock and 28 with a tuner. My truck seems to not have the 0 to 60 speeds as my old truck. Just seems to be lacking some thing.
Old Feb 3, 2012 | 12:15 PM
EpicCowlick's Avatar
EpicCowlick
21 psi is peak stock pressure. I haven't heard if tuners are changing that.
Old Feb 3, 2012 | 12:24 PM
B HOOFED's Avatar
B HOOFED
21 psi is the most I have seen either towing or running empty. This truck seems to do more with less boost pressure compared to the previous model.
Old Feb 3, 2012 | 01:31 PM
darren32's Avatar
darren32
I have seen up to 38 PSI tuned pulling a 12k trailer up 9% grade on one of H&S early tunes. Subsequent tunes seem to have brought that down a bit. In the cab it sounds like you are standing in front of a turbine (with aFe intake
A WFO pull on hot will get you into the low 30's I believe...
Thanks
Old Feb 3, 2012 | 01:59 PM
cummins cowboy's Avatar
cummins cowboy
spiking to about 21 is what I see, I am really surprised at how little boost these trucks run at considering the power. my '06 dodge tuned and producing similar power to my stock ford would spike to around 35 psi. one thing I have noticed is the ford seem to have ALOT of grunt and acceleration initially but once the revs get up there its all gassed out. thats a hint to me that HP on these trucks could be raised substantially without changing anything down low. imagine if they added more fuel from 2700 to 3200 rpm that could easily push these trucks to 500 horse, but in the normal rpms we use the trucks it would not make a difference.
Old Feb 3, 2012 | 02:03 PM
darren32's Avatar
darren32
Yes, simple H&S Black Maxx and deletes will get you to 497 RWHP with the stock fuel / air systems. Not what you could get out of a 6.4 but still pretty decent.
Thanks
Old Feb 3, 2012 | 02:31 PM
GDAWG 2012XLT
Thanks. I guess I need to get use to my new truck. I havent pulled my 5th yet to see how this truck will handel it. All I hear is good things with the 6.7L.
Old Feb 3, 2012 | 06:17 PM
kper05's Avatar
kper05
As others said, 21 PSI is max stock.
Doing more with less.
Old Feb 3, 2012 | 08:35 PM
Andrew010's Avatar
Andrew010
Low 30s thanks to H&S!
Old Feb 3, 2012 | 11:25 PM
shadowSVT's Avatar
shadowSVT
I saw in the high 30's with my 6.0 and my 6.4.
on this, I don't think its ever gone over 22, even pulling 14K up a serious grade.
like others said, this engine does a lot more with a lot less boost.
SRBF150
Aug 8, 2015 06:56 AM
Teds
Jul 22, 2012 03:14 AM
CC'sDad
Mar 8, 2006 05:01 AM
jeepnford
Apr 28, 2002 09:13 AM
