Hydroboost question
Old Mar 8, 2020 | 01:17 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Hydroboost question
So I have installed a hydroboost set up on my 79 Bronco. But the pedal doesnt want to come all the way back up fully so I have to use my foot to pull the pedal up. The brakes still work. I think the issue is the leaking at the proportioning valve sensor is allowing some air in the brake system.
I tried the aftermarket little brass ones, but they kept leaking. What have yall done to solve this problem?
Thanks
Old Mar 8, 2020 | 07:47 PM
73fummins's Avatar
73fummins
4wd Low
When I did mine it did the same thing. Replaced it with another used one still did it. Finally put in a new one and the problem was gone.
Old Mar 8, 2020 | 09:49 PM
ManfredVonRichtofen
where did you get a new one at? Did you remove the spring inside so the flow is equal in the front and rear brakes?
Old Mar 9, 2020 | 06:10 AM
Shortbox4x4's Avatar
Shortbox4x4
Thanks
Did you assemble your Hydroboost set up from parts or did you buy a complete kit and just installed it?
Just curious. I’m just trying to learn any quirks the systems might have during install etc...
I ordered a complete kit from Wild Horses. From what it looks like it’s plug and play. I’m trying to avoid looking for used parts and cobbling it together to avoid any headaches. I don’t have a ton of extra time to source parts from the pick and pulls etc...that’s why I went the complete kit route.
Old Mar 9, 2020 | 08:25 AM
ManfredVonRichtofen
I put mine together with various parts.
Old Mar 9, 2020 | 05:04 PM
flowney's Avatar
flowney
How you handled the return lines (2) may be a factor. The PS pump is another. Most will use a Saginaw "canned ham" unit b/c it has to have extra capacity to handle both PS and PB instead of just PS. Of course, the condition of the parts used is a factor as well.
So, share more details to help folks help you.
Old Mar 9, 2020 | 07:03 PM
lafermedavid's Avatar
lafermedavid
I believe wild horses uses hydratec
Old Mar 9, 2020 | 07:11 PM
ManfredVonRichtofen
yeah i have a sag pump.
Old Mar 10, 2020 | 09:56 AM
flowney's Avatar
flowney
Does it have two return lines? If not, how are you handling the PS and PB return lines, a T fitting? A T fitting can create a back-flow condition. Here is the plumbing diagram that Hydratech offers:
Note that they prefer dual lines but, failing that, one can use a T as shown to minimize back pressure / back flow. Note also the use of AN -6 sized lines. There are also high volume Ts that can be used to lessen flow issues.
mv7fd
1978 - 1996 Big Bronco
Oct 29, 2016 09:18 PM
74fordhighboy
Jul 10, 2010 02:34 PM
hpheltersnach
Jan 7, 2009 11:49 PM
rwjr
Dec 19, 2008 05:42 PM
