brake booster question?
Old Jul 9, 2010 | 10:33 PM
74fordhighboy's Avatar
74fordhighboy
I have a 74 f250 4x4 that I put a body off of a 79 150 body on to. The brakes were hanging up on 150 thought it was proportioning valve got a new one didn't fix the hanging up problem. I did notice that when I start the truck the pedal travels down about 2 inches. With
That being said would a brake booster make the brakes hang up? And after u shut the truck off pedal comes back up?
Old Jul 9, 2010 | 11:34 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Check the pushrod length adjustment between the brake pedal and m/c. Also check the pedal return spring.
Old Jul 10, 2010 | 02:34 PM
steponit's Avatar
steponit
You need the complete brake pedal assembly from a 79 .
You can't mix and match
