squealing noise?
Old Mar 7, 2020 | 10:19 AM
Frank79's Avatar
Frank79
squealing noise?
I noticed the last few days when towing a trailer that when I get on the pedal, as the truck shifts gears ( I think its from 3rd - 4th) I get a little 1/2 second squeal that sounds like a belt slipping? Not sure where its coming from.
Old Mar 11, 2020 | 01:45 PM
Frank79's Avatar
Frank79
So now this is happening without the trailer being hooked up. I have narrowed it down that the squeal happens when the truck shifts from 3-4 and my MPH are between 55-60. Doesn’t happen during causal driving only when you get on the pedal hard.
Old Mar 11, 2020 | 02:02 PM
TireFryer426's Avatar
TireFryer426
Could be a torque converter issue. It goes full lockup in 4th. Mine doesn't squeal, but it feels like its slipping or just half shifting going from 3 to 4. Dealer claims its perfectly normal, but it didn't shift like that when it was new.
Definitely have the dealer look at it. Or if you have Forscan see if you can correlate torque converter lockup to the squeal.
Old Mar 11, 2020 | 09:30 PM
Frank79's Avatar
Frank79
so soon with only 20k miles? Ughhh. This sucks!
Old Mar 12, 2020 | 08:27 AM
TireFryer426
Yeah, its annoying for sure. 20k is about where mine is. Hopefully your dealer takes care of you. Keep us posted on what they find
Old Apr 20, 2020 | 08:37 AM
Frank79's Avatar
Frank79
Just left dealership. They have no clue on the sound. Said it could be plastic/ rubber bushing etc. he told me it would take a week or two to diagnose but for me to keep and eye on it Incase it gets worse.
They said they would send a email to ford to see if anyone else had this issue and what the cause may be.
Old Apr 20, 2020 | 09:08 AM
stephen.osborne1's Avatar
stephen.osborne1
My '13 PSD had a similar sound... Couldn't figure it out. Only did it at certain RPMs, when shifting, under load.... You get the idea. Turned out to be an exhaust gasket after the muffler. The "collector" type gasket was split and under certain conditions, exhaust would escape through the split, causing a squeal sound. Easy, cheap fix. Worth a look underneath. Good luck.
Old Nov 9, 2020 | 09:57 AM
Frank79's Avatar
Frank79
I know it is been a few months. My problem still exists. It’s like clock work now.
here’s a thread bump for those who have this issue and may know what it is.
Welk49
Aug 16, 2008 12:01 PM
CounterMaker
Jul 5, 2007 07:12 PM
Forddieselweasel
1997 - 2003 F150
May 25, 2006 08:41 AM
TheDuke
Jun 6, 2005 05:50 AM
surfer8400
1983 - 2012 Ranger & B-Series
Mar 19, 2004 09:56 AM
