Interesting info
Old Mar 4, 2020 | 10:28 AM
Listor's Avatar
Listor
Interesting info
Adapter: ELM327 v1.5
Min.delay: 32 ms (Good)
Errors:
- CAN ERROR: 3 ( 0.5% )
Model: Ford F-Series Super Duty
Engine: Direct Injection - Turbo
Capacity: 7.3L
Generation: 2003 MY
Fuel type: Diesel
Transmission gear: Automatic
OBDII - On Board Diagnostic II
Bus: PWM
IC - Instrument Cluster
Bus: PWM
Part number: 2C3F-10849-HJ
Software version: 2001-06-15
Odometer: 393176.1 km
PCM - Powertrain Control Module
Bus: PWM
Part number: 2C3FDF
Strategy : TNAA7S3
Hardware type: DPC-462
Copyright Ford Motor Co. 2002
RCM - Restraint Control Module
Bus: ISO
Part number: 1C3ABD
Software version: v5 1999-07-09
GEM - Generic Electronic Module
Bus: ISO
Part number: 2C3T-14B205-AA
Software version: v1 2000-04-07
ABS - Antilock braking system
Bus: ISO
Part number: 2C34-2C346-BE
Software version: v3 2001-06-01
i find it interesting that my odometers only shows 244322.7, does this mean they have replaced the cluster or rolled it back somehow?!?!
Old Mar 4, 2020 | 10:42 AM
slowsure's Avatar
slowsure
Conversion:
393176.1 KM = 244307.4 MILES
Where did you pull this info? Forscan?
Old Mar 4, 2020 | 11:52 AM
Listor's Avatar
Listor
Originally Posted by slowsure
Conversion:
yes from forscanview on my phone
Old Mar 5, 2020 | 06:48 AM
Listor's Avatar
Listor
===OBDII DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC===
===IC DTC B1352===
Code: B1352 - Ignition key in circuit fault
Module: Instrument Cluster
Diagnostic Trouble Code details
===END IC DTC===
===IC DTC U1262===
Code: U1262 - SCP Data Link Fault
SCP Data Link Fault
Operator Action
Run self test.
All CMDTCs
Fix all relevant DTCs then clear codes and retest.
Note:
DTCs that start with 'U' are faults which occur during module-to-module communication.
Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle.
===END IC DTC===
===PCM DTC P0470===
Code: P0470 - Exhaust Back Pressure sensor circuit malfunction
Module: Powertrain Control Module
Exhaust Back Pressure (EBP) sensor circuit malfunction.
--Possible Causes--
- Open signal return.
- Damaged EBP Sensor.
- Damaged PCM.
===END PCM DTC===
===PCM DTC P1211===
Code: P1211 - Injector Control Pressure Higher/Lower Than Desired (engine running)
Possible causes are:
An incorrect oil level
Low fuel pressure.
Poor oil quality
High pressure oil system leak
High pressure oil pump
ICP Sensor
Injector Control Pressure Regulator
===END PCM DTC===
===RCM DTC ===
Module: Restraint Control Module
===END RCM DTC===
===GEM DTC ===
Module: Generic Electronic Module
===END GEM DTC===
===ABS DTC ===
Module: Antilock braking system
===END ABS DTC===
more info from forscan view
Old Mar 5, 2020 | 06:56 AM
SkySkiJason's Avatar
SkySkiJason
Conversion:
Seems weird the PCM reads that in metric. As far as I know that data (odometer) is not stored in PCM - only in cluster.
Old Mar 5, 2020 | 07:00 AM
Listor's Avatar
Listor
wow i did not catch that it was metric, so its not wrong LOL
really freaked me out
fstfwrd
Feb 4, 2025 04:03 PM
Ashton David
Large Truck
Oct 24, 2020 11:45 AM
wharrell
6.7L Power Stroke Diesel
Jul 8, 2015 12:05 AM
rugbyjwc
Sep 12, 2008 07:13 PM
MYFORD1978
May 10, 2007 01:53 PM
