Ford F650XL Super Duty Module Replacement
I am having a very hard time finding a module to replace my existing in my Ford F650XL Super Duty. I need to replace it because it is sensing a break issue that doesn't exist and activating a constant ringing alarm in the cab when I am driving.
Attached is a photo showing what I need to replace.
Does anyone now how I can locate one? I contacted Module Experts and they told they cannot find one.
Thanks for any help.
Ashton
Ashton
The reason you cannot locate the module is:
1C3T-14B205-CB is the ID Engineering number .. not the part number.
No part numbers are marked on parts after 1956, just casting & ID Engineering numbers, when applicable.
Dealers use Master Cross Reference Catalogs to cross ID numbers to part numbers, but I don't have one for this new a truck.
You'll have to contact a dealer to get the part number. There's a Ford dealer in White Bear Lake MN that sells parts on the net for dealer cost +10%.
autonationfordwhitebearlake.com also has an online parts catalog, where you may be able to find the part number. It also lists the MSRP & discount prices.
Perhaps I'm a little to the party, but I took the liberty of Google searching that number, and came up with someone who posted a VIN to their truck which happened to be a 2001 F-650.
In OASIS, and then HvBOM, that number 1C3T-14B205-CB cross references to the latest Ford part number which is EC4Z-14B205-BRM, or Motorcraft part number MFM-17-RM.
Hope this helps.
Hope this helps.
No you're definitely not late. This module has become a needle in a hay stack. I have been talking with a module dealer and originally gave the him the number, EC4Z-14B205-BRM. He told me this was a generic number and he couldn't locate anything for this.
When I sent him the attached picture he said that this was what he needed, but couldn't find anything.
Do you how I can search for this module with these three numbers you have listed here?
I spoke with someone at Ford of white bear lake. He was helpful but was not able provide me with one. He did give a lead to Circuit Board Medics for repair of the Gem Module. I have been preciously told that they generally cannot be repaired though.
I am looking a a resource to locate a scrap yard that has a 2002 Ford F650XL Super Duty, do you know how a good resource for located one in the United States?
I looked on the D2D, no one has any. I also looked on PartsVoice.com & rearcounter.com .. the two parts search websites that anyone can access. No one has any.
