Tiny holes in floorpan
Old Mar 2, 2020 | 07:43 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
How do you guys repair these tiny holes? Do you just cut out the old pan and replace it? I am trying to get by with little as possible. I was debating about just welding it to fill in and grinding it down
Old Mar 2, 2020 | 07:59 PM
fordguy2100's Avatar
fordguy2100
pics would be helpful. If you are talking about pin holes from rust... grind off all the rust and if they are still fairly small... just weld them up. If it starts looking like swiss cheese... may be time for new floorpans.
Old Mar 2, 2020 | 08:48 PM
RalphXL's Avatar
RalphXL
Rust metal doesn't weld to good. If it is thin enough to make holes you will probably blow through it when you try to weld it. Weld in new metal or for pinholes you could try fiberglass and Por-15.
Jess
Old Mar 3, 2020 | 10:14 AM
Lrrr-RulerOfOmicronP's Avatar
Cut out the rusted section and weld in new.
Old Mar 3, 2020 | 05:27 PM
flowney's Avatar
flowney
Pin holes are just the more visible aspect of severely rusted and weakened metal. Eventually, you'll put your feet through the floor and pull a Fred Flintstone. I'd recommend using as much of a patch panel as you can. Happy welding.
riverguideguy
May 4, 2013 11:06 AM
Microchudd
Jun 11, 2011 02:26 PM
dcunningham
Paint & Bodywork
Jan 16, 2007 09:47 PM
DrBlackgaard
Paint & Bodywork
Apr 25, 2003 04:46 PM
fordxxx
Paint & Bodywork
Jan 28, 2003 01:04 AM
