rust repair using solder
Old Jan 27, 2003 | 01:54 PM
fordxxx's Avatar
fordxxx
I fixed a rust hole about the size of a dime on my fender by grinding all the paint off the area and soldering a piece of galvanized sheet metal over top with a propane torch. I then ground the edges down and used some filler to smooth it all out.
The metal I used was 1 gauge thicker than that used for heating ducts.
When I was done I soaked the back side with rust converter and then rust inhibitor.
What do you guys think of this method? Will it last?
Old Jan 27, 2003 | 10:30 PM
Mike W's Avatar
Mike W
You should be ok if you got the rust stopped. The more I see of rust, the more impressed I am of it's ability to keep going.
Old Jan 28, 2003 | 01:04 AM
cid's Avatar
cid
You may have problems with the flux in the solder. If it is acid based this will present adhesion problems down the road. Wash with water next time to neutralize the acid. It was common at one time to punch holes in sheet metal and insert a slide hammer into the hole to pull out dents. The holes were then filled usind a soldering gun. It helped if you countersunk the hole first. This added a little more volume to the hole and aided in applying the solder.
Aftrmidnite
Oct 15, 2014 08:09 AM
smblokford
2009 - 2014 F150
22
Mar 27, 2014 09:33 AM
willeo6709
Nov 6, 2008 10:15 AM
va150
Paint & Bodywork
Sep 20, 2007 07:41 AM
