Sponsored by: Auxito
Frt End Question
Old Feb 26, 2020 | 10:30 AM
remmers's Avatar
remmers
Frt End Question
Im looking at a 2003 f-150 ext cab 4x4, it has higher miles but body is in great shape and was told it runs great.
Well since its a hr away I have been asking lots of questions and he said the only issue it has is the frt end shakes at Higher speeds on dirt/bumpy roads but on smooth roads it doesnt do it.
He said his friend said it was ball joints, Im wondering if might be something else like a wheel bearing?
I would take it to my mechanic who said he would shake it down for free but its a hr away
The price is really good for what I am looking for and not afraid to put some repairs into it
Old Feb 26, 2020 | 11:52 AM
Lime1GT's Avatar
Lime1GT
I can only tell you of my 02 4x4. I bought used at 60000 miles safety showed both inner and outer tie rods changed. Between roughly 85000 to 110000 miles I've changed front shocks; 2 sets of stabilizer bar links (first set broke one link); 1 set of stabilizer bar bushings; both lower ball joints and both wheel bearing assemblies. My brother had an 03 but sold with low mileage on it. Warranty on his only changed the idle control arm. So you can see it can be anything with miles on it. Best to have someone check it. You might also want to check the price of parts if you want to or need to replace the whole front end system. You can build a list online at rockauto or napa say to see if the price exceeds what your willing to shell out. Of coarse labor is extra.
Old Feb 26, 2020 | 01:17 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Had the same problem with my 2003 and it was the idler arm.
Denny
Old Feb 26, 2020 | 05:22 PM
Clutch5sp's Avatar
Clutch5sp
Sway bar bushings are almost always worn or completely missing. Just did an entire front end rebuild on my 2001 4x4 F150. Upper & lower ball joints were worn out as well. I'm still chasing steering issues even after replacing the steering shaft along with all components including shocks & rotors/pads. I've tightened the steering gear box 20+ f'n times with little results. A new gear box is the last part to be replaced and it tests BAD. Input shaft moves a scooch while the arm doesn't.
Old Feb 26, 2020 | 08:25 PM
steve(ill)'s Avatar
steve(ill)
normally wheel bearings will show up on smooth or bumpy roads........... If it only shows up on BUMPY.. probably more like shocks or tie rod ends.
Old Mar 16, 2020 | 11:56 PM
eighthof8KS's Avatar
eighthof8KS
Does the truck live on a dirt road? The truck I bought did. I had to replace everything on the front end. I did most of the work myself, so I learned a lot, and saved a bunch.
Old Mar 19, 2020 | 12:09 PM
lildobr's Avatar
lildobr
I wouldn't worry about it most likely tie rod ends.Inspect movement while he turns wheel back and fourth slowly.Talk him down and just be careful going home with it.
Old Mar 22, 2020 | 09:23 AM
honda250xtitan's Avatar
honda250xtitan
its due to have the whole front end rebuilt anyways. Moog and amazon brands have complete kits.
Old Mar 28, 2020 | 10:58 PM
Oredigger's Avatar
Oredigger
My old 02 used to go through a set of sway bar links a year until I switched to Moog parts for all my replacements. Would behave badly on bumpy roads when they broke. Worth the money for quality parts imo
Old Apr 8, 2020 | 11:16 AM
Clutch5sp's Avatar
Clutch5sp
Same here...bought an old fixer upper. Found an entire front end suspension kit ($140) on Amazon by Detroit Axle. All joints have grease fittings, Add sway bar & lower bushings for $50. Then add the cost of a shop press & ball joint tool from HF Tools for $200. Be sure to clean everything and paint it. Drove weird so the steering shaft (&60) was replaced & then the steering box ($120) after trying to adjust it. Looks & feels new after an alignment ($100) !
MOST IMPORTANT...make sure to have a 35mm socket ($10) to remove the axle bolt.
Cpap
Jul 5, 2017 07:54 AM
ag-ford-4x4
1997 - 2003 F150
21
Apr 29, 2015 08:41 AM
984x4F150
1997 - 2003 F150
Sep 5, 2009 02:44 PM
ponch37300
Aug 20, 2008 08:32 PM
RedCrewCab4x4
Jan 3, 2004 09:08 PM
