Regular cab replacement
Old Feb 20, 2020 | 08:29 AM
7.3diesel1's Avatar
7.3diesel1
I have a 1988 regular cab F250 4x4 that is shot.
Does anyone know if I can use a regular cab from a 2wd truck, will it bolt right up or is there going to be modifications?? Thanks!!
Old Feb 20, 2020 | 08:59 AM
jas88's Avatar
jas88
The only mod would be to cut the holes in the floor where the trans and the xfer case shifters come thru.
Old Feb 20, 2020 | 07:57 PM
sloopdog1's Avatar
sloopdog1
Does the 88's not have a bolted in cover plate for the shifters? My 93 has a small plate covering the 4x4 shifter hole.
Old Feb 21, 2020 | 11:12 AM
jas88's Avatar
jas88
For the transmission, depends on the transmission. Manual trans = yes, auto trans = no.
For the xfer case, the only time I have seen the plate glued over the hole is on 4x4 trucks with electronic shift. My 4x2 did not have the hole, I had to cut it with a jig saw.
Old Feb 21, 2020 | 12:19 PM
sloopdog1's Avatar
sloopdog1
Mine does, I saw it when the carpet was out so I could remove the large cover when replacing the clutch and transmission.
Old Dec 30, 2020 | 10:31 AM
7.3diesel1's Avatar
7.3diesel1
Would a dash ***'y form a '88 F250 bolt right up in a '94 F250 ??
Old Dec 30, 2020 | 10:32 AM
7.3diesel1's Avatar
7.3diesel1
Dash ***'y fitment
Old Dec 30, 2020 | 12:23 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
No. This is where the pitfalls start to show.
Any 80 to 96 cab and the 97 F250HD will bolt to the frame as long as they are the same configuration and yes, the body lines will match up. Holes in the floor can be resolved with the proper tunnel cover. Dashes and wiring becomes the devil in the detail. There are three main groups, 80 to 86, 87 to 91 and 92 up. Dashes do not easily interchange between groups and the firewall holes are completely different between each generation.
If you are changing cabs between weight classes beware as the VIN assigned to the replacement cab will determine your weight classification for registration purposes.
Old Dec 30, 2020 | 02:39 PM
tjc transport's Avatar
tjc transport
i ain't rite
also, diesel and gas wiring are different. so if the new cab is gas, you will need to use your current diesel wiring harness and dash to get everything to work rite.
i am going through this now. putting an 87 F150 gas 2 wheel cab on my 88 4X4 diesel.
Old Dec 31, 2020 | 01:38 AM
OhioFordFarm's Avatar
OhioFordFarm
Not to try to hijack this thread but, I have a 94 F250 4X4 with a shot cab, Have a really nice 88 F 150 rwd cab I would like to put on the 94. Both auto's but the 150 is a AOD and the 94 is E4OD. Think I have harness and ECU for a 91 351 with a E4OD. Would have to add the OD cancel button and light in the cab. Am I close to making things workable or am I overlooking something major?
Old Dec 31, 2020 | 03:14 PM
Diesel_Brad's Avatar
Diesel_Brad
NOTHING inside the 88 cab will work on your 94 truck. The 94 dash will NOT bolt into he 88 cab. The 91 harness will not do you much good either. The wire harness layout is different from the 87/91 cab and the 92-97 cab
Old Jan 1, 2021 | 06:52 AM
OhioFordFarm
I hope to pretty much make the drive-train the same as a 91 with a E4OD. IF I remove the cab, and the wiring off the 94 engine and chassis, then Using the harness off a 91 with a 351 and a E40d I dont see why you say nothing will work? Cab will bolt on the frame, I have a distributor, and everything off a 91 351W I think I'll need. I'm just putting a newer frame, motor, and trans under the cab? will need to install wiring for 4X4 indicators and OD cancel button and light. I would think the 91 ECU should shift the 94 trans fine?
So the motor will no longer be a mass air, and changed back to a speed set up. Still better then having a running truck with no usable cab, and a great cab on top of a unusable truck.
Old Jan 1, 2021 | 05:00 PM
NotEnoughTrucks2014
Pretty sure your 94 will not be mass air, but it will be roller cam. Nothing wrong with that, but you will need the engine harness from the 91. Also will need to use the 91 distributor, (Make sure you have the right gear for the roller cam). You can use the later distributor and the remote mount module with a little wiring.
You will find some difference in the front frame horns and bumper mounting.
There is something about the E4OD in that the earlier vs. later versions had some protection diodes relocated from the transmission to the ECU. Not sure when the cutover was, but a little searching should find you some answers.
Good luck.
66P51
May 29, 2016 02:50 PM
nickelndime79
Oct 25, 2012 01:04 PM
jdasilva644
Mar 28, 2010 06:49 PM
Tony 1
Paint & Bodywork
Sep 1, 2002 11:03 PM
