cold temp high idle
Old Feb 16, 2020 | 06:03 AM
hdman6's Avatar
hdman6
Question cold temp high idle
I had a 7.3 up until last october when I upgraded to a 2019 6.7. So when temp were cold cold ( like last night here in ny it was 4 degrees) my 7.3 would high idle like its supposed to do and when i stepped on the brake pedal it went back to idle and off i went. On my 6.7 the high idle seems to stay on and when you shift to drive it has quite a lurch. Is this normal? I was ecpecting the same brake pedal to deactivate the high idle. thanks Jeff
Old Feb 16, 2020 | 02:08 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
That's not normal, when you step on the brake, my 6.7 idles down. Maybe bad switch/sensor on the brake pedal?
Old Feb 16, 2020 | 11:56 PM
flumpydog's Avatar
flumpydog
Same with mine, as the other day it was -19 C here and mine was idling at around 1100 rpm and this dropped as soon as I stepped on the brake to engage the transmission in drive. Sounds like your truck has an issue.
andres0517
Feb 5, 2013 09:09 PM
meier63
Dec 13, 2010 08:24 PM
mblanken881
Feb 27, 2009 07:45 PM
chairman13
6.4L Power Stroke Diesel
Oct 17, 2008 01:19 PM
west tn 6.0 powerstroke
Dec 17, 2003 04:17 PM
