Engine Swap
Old Feb 15, 2020 | 05:36 PM
Dave Davis's Avatar
Dave Davis
Engine Swap
Excuse me if I’m posting in the wrong place, I spent some time looking for something related without success so here I am.
I have a 1995 F250 with a 460 engine that is no good so I found a 460 that is almost exactly the same and only 52,000 in the motor. The problem is it is an 88 and they did not have a crankshaft positioning sensor but now that it has a 95 wiring harness it runs like total doodoo, OBD11 says the crankshaft sensor has a bad circuit which makes sense because there is nothing to plug it into. So to make it work I have to change the timing cover. Once I do that will it work and/or will the other sensors fail because the brain isn’t compatible with the 88 stuff. Thank you for any response you can give me. I hope my question was through enough. Everyone have a great day
Old Feb 15, 2020 | 06:54 PM
timbersteel's Avatar
timbersteel
Is your '95 460 a Cali OBDII engine? Most 460's were non OBDII except in California in '96-97. I could be wrong on those years though.
Old Feb 15, 2020 | 07:18 PM
85e150's Avatar
85e150
Everything induction, electronic, electrical, sensor etc from the '95 should have been transferred over to the "new" motor. IF it's at all different. Clearly you need the crank sensor. What else was different?
Old Feb 16, 2020 | 09:18 AM
torq'ta 5 8's Avatar
torq'ta 5 8
doesnt he need to remove harmonic balancer from 88 and use the harmonic balancer with tone ring on 95, to swap over for sensor to work
Old Feb 16, 2020 | 12:53 PM
Diesel_Brad's Avatar
Diesel_Brad
Not sure why you would have a crankshaft sensor. They were only on cali trucks from 96&97 I thought
Thomsponmichael
Jan 27, 2020 11:48 AM
RL&C
Aug 31, 2014 11:21 PM
Fords/HD/Cat
15
Jan 24, 2011 02:35 PM
beattle55
Feb 21, 2006 01:50 PM
Coogles
Mar 8, 2004 06:50 AM
