2006 power stroke dome light issues?
Old Feb 13, 2020 | 03:38 PM
Dan Hardel's Avatar
Dan Hardel
Help please! First time posting. So I think I have 2 issues. Dome light comes on when it wants. Driving or in the driveway. No door ajar light ever. Have already lubed the door switches numerous times with wd and PB blaster. Just changed the ignition lock cylinder and duct taped the door chime tab. So no door chime when door is opened with keys in or out. However when the truck goes into the dome light craze if you open the drivers door it chimes as if the key is in the ignition? How is that possible? Hopefully someone can help me out. Thanks
Old Feb 13, 2020 | 09:40 PM
Visurveyor's Avatar
Visurveyor
How about the radio? Is it acting up to as far as power or lighting. Gremlins!! Might wanna check on you dash cluster. They are known to start weird stuff.
Old Feb 13, 2020 | 10:00 PM
jmtbiggin's Avatar
jmtbiggin
I had a similar issue, accessory delay relay fixed me, 10 bucks!
https://www.ford-trucks.com/forums/1...o-problem.html
Old Feb 13, 2020 | 11:03 PM
Dan Hardel's Avatar
Dan Hardel
No the radio is fine. I started smacking the dash right above and to the right of the speedo tonight and got the inside lights to come on as well as the door chime. Hit it again and the lights would go out. So I'm suspecting something under the dash. Cluster or a shorted wire. I'll update when I figure it out. Thanks
Old Feb 16, 2020 | 12:58 AM
Dan Hardel's Avatar
Dan Hardel
So the problem I finally found was the blue connector on the cluster. Sending the cluster to circuit board medics.
Old Feb 16, 2020 | 12:16 PM
jmtbiggin's Avatar
jmtbiggin
I called them when I had my problems, they said not to send my cluster, that the problem was elsewhere. Seem like decent folks
Old Feb 16, 2020 | 10:45 PM
Dan Hardel's Avatar
Dan Hardel
What was your problem Jim?
Old Feb 17, 2020 | 12:21 PM
HydroTek's Avatar
HydroTek
You can pull the cluster apart and re-flow the solder on the connector -- that is the common problem
o'course that depends on your abilities and tools -- circuit board medics can do the job
Karlow
13
Sep 19, 2020 04:48 PM
sasq40
Mar 20, 2010 06:01 PM
bentheplumber
Jul 5, 2007 12:04 AM
MrSlithers
1997 - 2003 F150
Mar 30, 2007 05:51 PM
junior964
1983 - 2012 Ranger & B-Series
Jul 29, 2003 09:04 AM
