DEF Fault codes
Old Feb 11, 2020 | 11:53 PM
mxer0022's Avatar
mxer0022
DEF Fault codes
Ok guys here is my situation. I had to replace my DEF heater. There was something I needed to run to the parts store to get to finish the job but my wife had the car at school and I didnt have the car seats to take my boys so I figured I would change the oil and fuel filters while I waited for my wife to get home. Well I cycled the key a bunch of times to prime the fuel system and I got the "in 50 miles speed will be reduced to 50 mph" message. I didnt think anything of it because my whole DEF system was sitting on the floor so I figured that was normal. Well I got everything put back together and now I'm getting a P130E and P204E code. They wouldn't clear with forescan. Took it for a drive thinking the pump just needed some time to prime. That didnt work. So I started researching those codes and found out they are permanent codes that cant be reset with a code reader. Anyone know how to get those codes to reset? I read something about having to have a certain amount of drive cycles to reset the code after repairs were made. Anyone know how many that is? I've got to make a trip from Utah to Washington state next week so I need to get this taken care of asap.
Old Feb 12, 2020 | 05:04 AM
Just Strokin's Avatar
Just Strokin
You are going to have to perform a drive cycle. There was a recent thread that had a similar problem created as you did with your truck.
Watch this video. It might be the answer to your problem.
Old Feb 14, 2020 | 05:32 PM
mxer0022's Avatar
mxer0022
Thanks Just Strokin, I think I'm just gonna pay the dealer to do it after I replace everything. The problem should be corrected but since I'm on the road a lot I figured I would just replace the pump and wiring harness as well for piece of mind. Once I've done that I'll have the dealer clear the codes. I tried it once and now I'm down to 11 miles to speed limiting.
ol_red92
Mar 3, 2014 11:43 AM
JonArmy
Dec 10, 2013 12:45 PM
Roy Jackson1
Jun 28, 2010 10:52 PM
05SD
Sep 13, 2005 10:22 AM
myvan
Aerostar
Jul 13, 2003 07:35 PM
