Sponsored by: Real Truck
Fuel filter change question
Old Jan 29, 2020 | 10:30 AM
frysl's Avatar
frysl
Can someone please clarify for me what triggers the change fuel filter message? Is it triggered by mileage, time, blockage? If I don’t get the message, how frequently should it be changed? Owners manual says 22,500 miles, am I reading that correct?
thanks
Steve
Old Jan 29, 2020 | 10:57 AM
Rod Jr.'s Avatar
Rod Jr.
Both fuel filters to be changed every 15,000 miles.
Old Jan 29, 2020 | 11:09 AM
Just Strokin's Avatar
Just Strokin
The message is triggered by the PCM. As above, many change it ever 2nd oil change or 15,000 miles.
Old Jan 30, 2020 | 08:06 AM
Overkill2's Avatar
Overkill2
The manual says by every 3rd oil change or 22.5k miles. I am now coming up on my 3rd oil change since I last changed my fuel filters. I monitor the fuel pressure from the frame mounted DFCM (diesel fuel conditioning module; primary pump/fuel filter/water separator) on my iDash 1.8. I've seen very little change in the PSI over the miles. Just a FYI. Very common here with the members to change them every 2nd oil change. Always use genuine Motorcraft filters. FD-4615 is the part number.
Old Jan 30, 2020 | 08:14 AM
dirthawg's Avatar
dirthawg
Larry, do you know if the PCM takes into account engine load, gallons used, etc. like it does for oil or is it just a mileage based counter that triggers the notification?
Old Jan 30, 2020 | 11:09 AM
Just Strokin
Dirt....I can not say since I have never run the filters to the 22,500 mile mark. I would think it is similar to the IOL and monitor pressures, engine hours and more to determine when it needs to be changed or wait for the 22,500 miles.
Old Jan 30, 2020 | 12:40 PM
dirthawg's Avatar
dirthawg
Same here. Guess somebody that waits for the light will have to chime in to see if it triggers at the same mileage.
Old Jan 30, 2020 | 02:34 PM
Overkill2's Avatar
Overkill2
I'm at about 24% on the OLM. I'll chime in... I'm probably at least at 20k miles on the filters now.
99SuperDuty2017
Jan 28, 2018 03:07 PM
Dascro58
6.7L Power Stroke Diesel
Nov 5, 2017 12:03 PM
markiemark
Apr 3, 2012 06:19 PM
'94IDITurbo7.3
20
Mar 8, 2012 10:14 PM
tesserra
Modular V10 (6.8l)
22
Sep 11, 2008 11:04 PM
