Engine noise
Old Jan 25, 2020 | 04:43 PM
Thommesf150's Avatar
Thommesf150
Engine noise
Hi I have a 79 f150 with a 400. I built it myself and it doesn’t even have 100 miles on it. It just started making this noise from the valve train on the driver side. Upon further inspection I took of the valve covers and I notice oil shoots out of the passenger pushrods, but it kind of just comes out on the driver side ones. It seems like some oil restriction thing tor faulty lifters. But I just need some help, thanks.
Old Jan 25, 2020 | 09:22 PM
mark a.'s Avatar
mark a.
How much oil psi is it making ?
Old Jan 25, 2020 | 09:31 PM
1TonBasecamp's Avatar
1TonBasecamp
What kind of noise is it?
And did you go through the proscribed "camshaft" break-in procedure right at the first startup? High speed for 30 minutes, no idling and all that?
If the valve covers are still off, I would check for bent pushrods.
I don't know why this is a thing, but for the last 15 years or so it's been an all-too-common situation after a rebuild that we have rocker arm, valve spring and pushrod troubles on these 335-series engines.
Never had that issue from the factory, and I really don't know what we could be doing so wrong, so often. But it's definitely common enough to make you look twice at your pushrods.
good luck.
Paul
Old Jan 26, 2020 | 03:11 AM
Ozzie H.'s Avatar
Ozzie H.
If possible, post a video/audio clip of the driver's side with the valve cover off while running.
Old Jan 26, 2020 | 08:08 PM
Thommesf150
The gauge in the truck says it’s making good oil psi, I did follow the cam break in instructions and for some reason I cannot upload the video that I have but I will investigate in the pushrods
swimmer_spe
2009 - 2014 F150
Jan 26, 2020 10:40 AM
emgee
15
Feb 7, 2015 10:47 AM
airharley
Apr 23, 2006 07:52 PM
javi2001
Dec 11, 2004 08:55 PM
dr-dirt
3.8 & 4.2L V6
Jul 16, 2004 12:57 PM
