valve chatter?
Old Jul 16, 2004 | 01:03 AM
dr-dirt's Avatar
dr-dirt
valve chatter?
Hi guys, just bought a 99 150 scab 4.2L with 41k miles. There is what seems to be valve chatter coming form the front of the engine. I was reading in a previous post of that noise coming from the oil pump. The noise is only apparent at idle. Then goes away as I step on the gas.
I was wondering if it was the oil pump, or the valves.
Thanks
Old Jul 16, 2004 | 09:43 AM
BrianA's Avatar
BrianA
Hello Dr.,
I dount what you are hearing is valve train noise. I here what I expect is the same 'ticking" sound you are hearing. Most noticeable at drive thrus where there is a brick wall just to the left to bounce the noice back into my open window.
Like you, whenever I accelerate, I no longer hear the noise.
It must not be anything wrong because it has been doing it for 4 1/2 years and 132,500 miles now!
Old Jul 16, 2004 | 09:56 AM
Cole's Avatar
Cole
Are you sure it's not just a sticky lifter ? It sure sounds like it. Does it sound like a 'Ticking " noise ?
Old Jul 16, 2004 | 09:59 AM
horizonhuskies's Avatar
horizonhuskies
Most likely the lifter would continue to tick as RPMs increased, but he only complains of the noise during idle.
Garrett
Old Jul 16, 2004 | 10:22 AM
James's f_1_fiddy01's Avatar
James's f_1_fiddy01
the problem is the oil pressure relief valve in the oil filter assembly....it snaps shut with a loud tick that you only hear at idle....it will not cause you any harm other than the noise....this was from Ford
Old Jul 16, 2004 | 12:57 PM
dr-dirt's Avatar
dr-dirt
thanks everyone. My wife asked, so I had to find out for sure
slickoneuk
Feb 8, 2013 04:42 PM
tkd
Oil & Lubrication
Oct 22, 2003 11:28 PM
Hawkdriver
Oct 5, 2003 06:48 PM
greenchicken
Bronco II
Apr 21, 2002 09:37 AM
joey
20
Jan 10, 2000 08:17 AM
