C1155 and trans problems
Old Jan 24, 2020 | 04:15 PM
metalman01's Avatar
metalman01
I’ve got a 2000 f350 7.3 4x4 with 260k on her, after several headaches getting the motor running right after mice had their way with it now I shift my attention to the transmission. OD light flashing 100% of the time and it will only shift 1-2 and sometimes 2-3 but almost never 3-4. Max speed is about 30 mph. Abs light was on so I pulled the codes and got a C1155 as the only code (front left wheel speed sensor). Would this cause my transmission problems like a bad bad would? Thanks in advance y’all
Old Jan 24, 2020 | 07:48 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, that code will not cause your transmission problems. The flashing OD light means transmission codes are stored. You haven't found them yet. When you have the trans codes we can help diagnose this.
Old Jan 26, 2020 | 05:33 PM
metalman01's Avatar
metalman01
Is there anyway to get the codes short of taking it to shop with the proper scanner?
Old Jan 26, 2020 | 06:50 PM
Mark Kovalsky
You can download Forscan free at www.forscan.org. You will need an ELM327 adapter to connect to the truck. I bought one from Amazon for less than $30.
Old Jan 26, 2020 | 07:51 PM
metalman01's Avatar
metalman01
I’m looking at them and have you had any experience with the Bluetooth version? I think it would be really handy to also have the live data on my phone
Old Jan 26, 2020 | 08:46 PM
Mark Kovalsky
I have a Bluetooth version. I couldn't get it to connect to my phone or to my laptop. The cable version works fine.
Old Jan 26, 2020 | 11:13 PM
metalman01's Avatar
metalman01
I’ll be ordering one soon then and getting those codes pulled to hopefully figure this thing out once and for all. Thank you for all of your help
SupraMario
Sep 22, 2019 08:11 AM
Phillipe
Sep 28, 2016 08:56 PM
007sniper
Aug 23, 2009 08:47 AM
powerstrokeddiesel
17
Apr 1, 2008 08:10 PM
chipper
May 14, 2007 06:09 PM
