Heated Steering Wheel
Old Jan 23, 2020 | 09:14 PM
kper05's Avatar
kper05
Star means "new for this model year." 2017 order guide 96U.
I read "with heat" as meaning heated steering wheel vs heat controls because I don't think that's a feature.
Old Jan 23, 2020 | 09:19 PM
Just Strokin's Avatar
Just Strokin
One thing most do not realize, the KR and Platinum also have Lariat badges as those two packages are upgrades to the Lariat.
Here is the 2016 DTC and trouble shooting guide for the 2016 heated steering wheel. Might help if you need more intensive investigation.
Old Jan 23, 2020 | 09:20 PM
kper05's Avatar
kper05
Originally Posted by Jaredabubba
Makes sense. Not sure about codes. I don’t have a way to read them yet.
I think checking for DTCs should be your next step. I don't know if you need OBDII Ford enhanced diagnostics on the software, Larry will probably know. I know it's needed for some BCM diag.
Old Jan 23, 2020 | 09:22 PM
Just Strokin
You can pull the codes with FORScan. Not sure if the phone app will pull them or not but the computer/laptop with an OBDII connection will pull them.
Old Jan 23, 2020 | 09:24 PM
Jaredabubba's Avatar
Jaredabubba
Alrighty. Thanks.
Old Jan 23, 2020 | 09:28 PM
kper05's Avatar
kper05
I didn't know that and those are KR wheels in that video. Did Ford stop offering the traditional KR interior? Platinum has a different grille.
Old Jan 23, 2020 | 09:35 PM
Just Strokin
The KR and Platinum are similar interior but the dash "wood" is different between them, as is the grade of leather on the seats.
Old Jan 23, 2020 | 09:45 PM
kper05's Avatar
kper05
I'm continuing to distract this thread but this is what I would expect when opening the door to a KR trim.
https://news.pickuptrucks.com/2017/0...o-gallery.html
And.
Last edited by kper05; Jan 23, 2020 at 11:19 PM. Reason: Added a grainy image for platinum example
Old Jan 24, 2020 | 06:36 AM
2009kr's Avatar
2009kr
My 2017 King Ranch F450 does not have anything on it that says Lariat. All trim badges say King Ranch.
Old Jan 24, 2020 | 08:11 AM
dirthawg's Avatar
dirthawg
Interesting discussion about the differences between the Lariat and KR. I get what Larry is trying to say, I suppose it's possible if the truck was special ordered without heated steering wheel. Every image I've seen of King Ranch interior has always had the Wavy S or snake emblem on the seats.
Either way the OP's truck has the option enabled in Sync, so either it had the heated steering wheel from the factory or the original owner enabled the heated steering wheel option with Forscan. I suppose if the OP could find the window sticker that matches his VIN we would know for sure.
2:00 shows the heated steering wheel button.
5:04 has the Lariat badge.
https://www.youtube.com/watch?v=pC8Vb9GYGdI&t=118s
The lady narrating that video must have been a flight attendant earlier in life.
Back to diagnosing his issue......Is the heated steering wheel identical to the non heated steering wheel in the 2017 trucks? IIRC the heated steering wheel in the earlier trucks had some wood grain at the top?
Old Jan 25, 2020 | 07:29 AM
ehagerty's Avatar
ehagerty
M
y 2011 F250 lariat w/Ultimate package has no heated steering wheel, just heated & cooled seats
Old Jan 25, 2020 | 09:39 AM
kper05's Avatar
kper05
I'm fairly certain the heated steering wheel was introduced with the 2013 Platinum trim and did not exist in the SD trims prior to 2013. Even the 2015 KR didn't have heated steering wheel, only Platinum. This expanded to KR and the 96U package at some point.
File Type: pdf
File Type: pdf
KWDAILYD
Apr 1, 2023 06:19 PM
z 97ford1
1997 - 2003 F150
Oct 2, 2021 12:13 AM
rdussell
6.7L Power Stroke Diesel
Mar 19, 2018 02:49 PM
longview1
18
Jan 18, 2011 12:03 PM
