heated steering wheel
Old Nov 28, 2018 | 07:55 PM
KWDAILYD's Avatar
KWDAILYD
I'm sure this has been discussed somewhere but I couldn't find anything using the search.
I have a 2017 F350 KR Power Stroke. My heated steering wheel seems to have stopped working. I turn it on in the display but no heat. Am I missing something? It was working earlier this week but yesterday and today no heat. Hopefully someone can point out something I am missing in settings. Thanks
Old Nov 28, 2018 | 08:07 PM
donjamer's Avatar
donjamer
Have you checked the fuses??
Old Nov 28, 2018 | 08:18 PM
KWDAILYD's Avatar
KWDAILYD
No, I have not checked any fuses yet. I'll try to figure out which one it is and do that. Thanks
Old Nov 28, 2018 | 08:47 PM
18SD_Lariat's Avatar
18SD_Lariat
Fuse 37 on the passenger side.
Old Nov 28, 2018 | 09:30 PM
srkr's Avatar
srkr
Let us know how this pans out, mine does seem as warm as last year.
Old Nov 28, 2018 | 09:44 PM
KWDAILYD's Avatar
KWDAILYD
Thanks. I was looking in the owners manual and found out which fuse but thanks for the response. I'll check it tomorrow. Looks like that fuse panel is behind the passenger kick panel.
I will report back on what I find.
Old Nov 29, 2018 | 06:58 AM
95snake's Avatar
95snake
That happened to my 2014 SHO, took it in and they had to due some kind of software update. It wasn't anything mechanical.
Old Nov 30, 2018 | 07:22 AM
07BlackGT's Avatar
07BlackGT
I’m having the exact same problem with my 2017.
in fact, it has been at the dealership all week. They are officially stumped. As of now they have traces all of the wiring, replaced the gateway module and the heat module. They are now contacting Ford engineering.
Old Nov 30, 2018 | 09:06 AM
kry226's Avatar
kry226
Have they checked the wiring in the wheel itself too? As in the heating element internal to the wheel?
Old Nov 30, 2018 | 09:23 AM
KWDAILYD's Avatar
KWDAILYD
I checked the fuse, it's good. I have an appointment next Friday at the dealer. Not looking forward to this
Old Nov 30, 2018 | 02:06 PM
07BlackGT's Avatar
07BlackGT
Not that I know of. They spent all week chasing communication issues with the gateway module that sits behind the touch screen. They said a replacement wheel is 3k.
Old Nov 30, 2018 | 03:39 PM
kry226's Avatar
kry226
IIRC, even a Raptor wheel with shift paddles isn't 15-20% of that cost. Shouldn't be close to that cost even with an airbag, which you very likely do not need anyway.
Old Nov 30, 2018 | 06:05 PM
Blwnsmoke's Avatar
Blwnsmoke
Steering wheels are between $750 and $930 plus shipping for the KR with heat (depending on adaptive cruise)
Old Dec 8, 2018 | 04:19 PM
KWDAILYD's Avatar
KWDAILYD
Took my truck to the dealer yesterday. Took them a little over an hour to determine the steering wheel needs to be replaced. Should be here by mid week.
Old Apr 1, 2023 | 04:16 PM
dbyford's Avatar
dbyford
4wd High
Did that fix the problem.?
What was the cost?
