dreaded Po720 code questions
Old Jan 23, 2020 | 11:17 AM
4wheelingpete's Avatar
4wheelingpete
Question dreaded Po720 code questions
Hello folks,
i know this question is been tossed around a lot about this stupid code. I need a good wiring diagram from anybody or a source for a new harness I drive a 2003 4x4 with the 5r110W and my local dealer tells me they're obsolete. couldn't even get me a harness diagram. Also, does the transmission have any ground wires connected to it from the chassis?
Currently going thru thru the harness to check for breaks or melted wires etc. its a big O'l mess! Please help! Thanks.
Little back story.
had the original tranny and the tow button light would flash periodically noticed a slight slippage on 3rd gear at the same time ( figured they were connected somehow) truck does have 380K so figured it was time to start looking for a new tranny. opportunity came to buy a "good" used one and I did. I installed it and this one will not only slip on 3rd gear it stays there. I have to shut the motor off and re-start the truck for it to go into 1st gear again. also once it slips and stays at 3rd gear my rpms are high. around 800. So my best guess that it wasn't the tranny that had an issue and more of a wiring problem.
Old Jan 23, 2020 | 03:50 PM
Yahiko's Avatar
Yahiko
Let me do a little digging.
Old Jan 23, 2020 | 03:56 PM
4wheelingpete
I’ll appreciate it very much.
Yahiko's Avatar
Yahiko
Okay here is the transmission diagram.
If you need the engine one I will have to create it from the Shop Manuals I have.
The engine diagran is the one for 2004. It should be nearly the same.
File Type: pdf
Old Jan 23, 2020 | 04:04 PM
4wheelingpete
Thank you for the diagrams!! I took apart all the looming and so far have found no broken wires. This thing is kicking my butt! Diagram will help tho! Thanks again!
Old Jan 23, 2020 | 05:55 PM
Yahiko's Avatar
Yahiko
Damage can be hidden under insulation.
Also call and talk to Ed or Scott and see if they can find you that harness.
https://www.ficmrepair.com
Old Jan 27, 2020 | 03:14 PM
4wheelingpete
Thanks for all your help. wires had continuity on both ends of the wire with no visible cut wires. If there's an issue with one of the wires it's probably broken strands somewhere (like you said. "under the insulation). Wish there was a way to put some volts on the wire to test the resistance. I ended up cleaning all the plugs and connectors with spray and dielectric grease. plugged everything back in and transmission is shifting and running perfect. I'm crossing my fingers it stays that way. Also going to change the alternator just in case. I'll keep you posted. thanks again for all your help.
Old Jan 27, 2020 | 04:17 PM
Yahiko's Avatar
Yahiko
Good to hear you got it working for you.
As for changing the throttle assembly I bet the part you take off will be good and your just spending money on a problem
that is not really there. I would give it a week or two. There are three variable resistors in the assembly. You might get a ODB2
dongle and Forscan to see what it's doing.
Old Jan 27, 2020 | 05:04 PM
4wheelingpete
Wasn’t going to replace the throttle assembly. I’m replacing the Alternator and It has a warranty so no out of pocket expenses. I gotta find somebody with the forscan around or near me. SoCal. It’s a bit pricey around me.
Old Jan 27, 2020 | 05:37 PM
Yahiko's Avatar
Yahiko
https://forscan.org/home.html
You can get the software fro free. So that only costs you for the OBD2 dongle.
That is only about a $30ish item.
Old Jan 27, 2020 | 05:52 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I was VERY fortunate to get a new transmission harness after the transmission shop that rebuilt my transmission hacked mine up trying to fix a hardware problem they caused.
They found one in Livonia (One of Ford's transmission plants) and sent it to me. It was no easy find, they had them all day for 2005-2007 Super Duty but not my 2005 Excursion.
It'll probably require a little work but I'm sure you can find one.
Old Jan 27, 2020 | 06:22 PM
TooManyToys.'s Avatar
TooManyToys.
That's not good to hear. It means they have exhausted all the inventory and no contract with the supplier to build more. Well, maybe not - if the demand is there they could possibly unless the supplier tossed the setup.
Old Jan 27, 2020 | 06:38 PM
4wheelingpete
Yeah, I tried my local Ford dealer with no luck. They just flat out said it was “obsolete” They gave me a number to a guy it’s on one of the replies to this same post where I can maybe find a harness. Have t tried the number so not sure if it’s new or used. But if I have any more problems I’ll definitely give them a call. Good luck with yours.
Old Jan 27, 2020 | 06:42 PM
4wheelingpete
Awesome man! Thanks for all the info! I’ll definitely get me a Dongle. I’m just using my SCTLivewire monitor
Old Jan 27, 2020 | 07:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If there is continuity from one end of the wire to the other you already put voltage through the wire and determined that the wire is good. But you could have a short to ground or a short to power.
That's where my office was from 1988-2007.
