Suddenly a Sooty Exhaust from my 4.9
Old Jan 21, 2020 | 01:32 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
I've recently noticed that my exhaust has gotten smellier and on start-up it will leave a sooty spot on the driveway (downward facing exhaust tip). It's also running a bit rougher - nothing terribly noticeable, but not as smooth as it was.
I haven't done any diagnostics yet - no error codes so far. Any best guesses? I'll start with a compression test and go from there.
Old Jan 21, 2020 | 02:10 PM
rla2005's Avatar
rla2005
Start with the easy items first. KOEO/Stored Code check. If good proceed to KOER tests. If good check the fuel pressure and inspect the fuel pressure regulator for signs of a ruptured internal diaphragm. Pull a spark or two then inspect for signs of rich A/F ratio. If they are fouled, inspect the rest of them.
groundrat's Avatar
groundrat
Could be a sticky injector or an O2 sensor reading extremely lean. Did you pull codes and get the all clear 111? Or just no check engine light yet?
Old Jan 24, 2020 | 09:23 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Haven't had a chance to dig any further into this, but thanks for the thoughts. Indeed I need to actually pull codes; so far, just going by no MIL.
I believe this is more of an oil soot rather than rich fueling soot, but it's worth checking all possibilities.
Old Jan 25, 2020 | 12:50 PM
groundrat's Avatar
groundrat
These truck do not trigger the check engine light when most of the codes are set. You could have half a dozen codes and never see that light. It only takes a few minutes to jump the EEC connector and count the flashes.Or pick up an Innova 3145.
Old Jan 25, 2020 | 01:50 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Yep, understood. I already have a Rotunda Super Star II, so no need to buy anything, just need to get out there..
Old Feb 15, 2020 | 03:12 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Finally got around to pulling codes yesterday and got a 21 (ECT) and a 24 (IAT). I suspect they both use a common ground - I wonder if that could be the actual issue since it would be odd for both those sensors to fail at the same time.
Old Feb 15, 2020 | 05:51 PM
torq'ta 5 8's Avatar
torq'ta 5 8
you can check them, cold, and then after warmed operating temp
Fuel Injection Technical Library » Engine Coolant Temperature Sensor (ECT)
Fuel Injection Technical Library » Air Charge Temperature (ACT)
this shows how to check grounds
Classic Broncos .com - Tech: Basic Vehicle Electrical Diagnosis for 66-77 Early Ford Bronco
paxmick
1983 - 2012 Ranger & B-Series
Dec 12, 2016 10:36 AM
PowerStroke_KiD
Mar 15, 2011 08:28 AM
CLIFF1989
23
Nov 19, 2009 05:28 PM
miked79928
Sep 29, 2004 03:06 PM
429SCJ
Mar 31, 2003 03:55 PM
