Running Rich
Old Sep 27, 2004 | 10:56 PM
miked79928's Avatar
miked79928
Running Rich
Need your guys help with this one. My 89 F150 with the EFI 4.9l seems to be running rich. It does not give off any codes, but it uses a whole lot of gas and the exhaust smells to high heaven. It just started to do this abot 3 months ago. Is there any way to lean out the air/fuel mixture? Any help is appreciated.
Old Sep 28, 2004 | 06:07 AM
EPNCSU2006's Avatar
EPNCSU2006
Check the fuel pressure and the fuel pressure regulator to make sure the pressure isn't too high, and that the regulator is not leaking fuel to the vacuum port.
Old Sep 28, 2004 | 12:34 PM
miked79928's Avatar
miked79928
Thanks. I will check that out.
Old Sep 29, 2004 | 03:06 PM
miked79928's Avatar
miked79928
Ok. This morning I pulled the codes again and I got code 41, which means that the oxygen sensor was reading lean all of the time. I replaced it and I think that it was the problem. The exhaust smell is not as bad, but I will have to see what kind of mileage I get on this tank to be sure.
brodie429
21
Dec 9, 2014 08:25 PM
roblalani
17
Feb 6, 2010 08:17 PM
1993 E-150
Dec 31, 2007 08:44 AM
harley1
1997 - 2003 F150
Jan 5, 2007 08:27 AM
rich51fordtruck
Jun 25, 2006 08:08 AM
