300 vs 302
Old Nov 20, 2019 | 01:59 PM
vintagequest's Avatar
vintagequest
300 vs 302
I’ve always been a big fan of inline 6’s. My ‘92 F-150 w/5.0 and 3.55 gears is a slug for towing. My ‘93 F-150 I6 with 520,000 miles and 2.75 rear smokes, leaks oil, and still pulls my trailer better. I am entertaining thoughts of an engine swap in the ‘92 and have an affordable lead on a 300/6. I’d prefer to not go with a larger engine than it has now. Which would you prefer.... a fresh 300/6 or a fresh 5.0?
Old Nov 20, 2019 | 09:06 PM
sloopdog1's Avatar
sloopdog1
Go with the six, you'll be happier.
Old Nov 21, 2019 | 02:16 AM
Sprinterhot's Avatar
Sprinterhot
Your smokin and leaky engine
Your current engine wont leak and will stop smoking if u install. an Envalve.
Old Nov 21, 2019 | 03:44 AM
TexasGuy001's Avatar
TexasGuy001
The 300 definitely does a little better with towing than the 302. You will probably be happier with the I6 since you already favor it over the 2. Personally I love the sound of a push rod V8. I have had an 85 with carbed 351, a 95 with 300, a 95 and now a 94 both with 302. My choice is a 351 swap for my current truck.
Old Nov 21, 2019 | 07:28 AM
jackietreehorn's Avatar
jackietreehorn
Looks like envalve is no longer in business. I would pick the 300 over the 302 for work/ actual light truck duties. The 302 is good for a commuter or toy truck that you just want to sound good.
Old Nov 21, 2019 | 09:17 AM
frank5079's Avatar
frank5079
I agree. After my 300 six died from blow-by, I swapped it for a 351 and I love it!!!
Old Nov 21, 2019 | 08:12 PM
TobyB's Avatar
TobyB
There isn't an easy way to increase the 6's displacement, is there?
Turbo!
I too have a respect for that engine- torque for days, super durable.
And very inexpensive to rebuild, if you start with a good candidate.
Mine has 3.55 gears, which seem to be a decent balance between
mileage and towing with 31" tairs...
t
Old Nov 22, 2019 | 09:33 AM
ZombieF150's Avatar
ZombieF150
I've an I6 and love it, my buddy has a 302 he likes his engine but has often commented that he wished he had the I6 while towing his camper. I've 3.08's in the truck and it does pretty well on the highway for mileage given it's age and miles on the clock.
Old Nov 22, 2019 | 12:06 PM
Conanski's Avatar
Conanski
A 5.0 is going to be the easiest to put back in and getting significantly more HP and torque than what the existing motor generates isn't hard or expensive, that will make for a much better towing experience. Of course there is no way a 5.0 will generate fat low rpm torque so it's going to be a different experience than an I6 and if that is what the OP is after then the decision is already made, but that is a bigger project with the need to change the frame towers and mounts, alter the exhaust, change the rad and hoses, and source a complete 4.9 EFI engine with all accessories and a complete engine bay 4.9 wiring harness and PCM.
Old Nov 24, 2019 | 10:13 AM
vintagequest
I don't think that'll do much for crank seals and pan gasket.
Old Nov 24, 2019 | 07:22 PM
Scndsin's Avatar
Scndsin
Originally Posted by jackietreehorn
Looks like envalve is no longer in business...
Yes, but there are plenty throttle body spacers available for those who like such.
Old Nov 25, 2019 | 04:05 AM
frank5079's Avatar
frank5079
I replaced my 300 because it was hemorrhaging oil out from every possible area due to excessive blow-by. From the time the oil leaks started, first the bottom side cover, then the oil pan, then the top valve cover...I was just chasing leaks all over. The oil started seeping past the head gasket and mix in with the coolant. Blown-by pressure caused oil to travel through the breathing tube into the air box. The final death knell was when the PCV valve kept blowing out. The resulting oil spray from the rear was ignited by a small crack in the rear of the exhaust manifold which resulted in a fire that burnt part of the rear engine harness.
Anyway, since I am more partial to v8s I decided on a v8 swap and if I was going that route I would have preferred a Lightning motor...but those aren’t very plentiful so I had to settle for a regular 351.
Old Feb 12, 2020 | 11:39 AM
Whiteboi27's Avatar
Whiteboi27
Blow by
Say man I know I’m a little late but how did it die due to blow by? My 4.9 i6 300 has bad bad blow by. I have a old empty quart of oil can with the oil breather tube down the neck instead of it going to the air box
Old Feb 12, 2020 | 03:45 PM
jas88's Avatar
jas88
I've owned both and put many miles on both and my 302 was better in every way than my 300 except for MPG. The 300 as this mountain of torque is a myth.
Old Feb 12, 2020 | 07:13 PM
jackietreehorn
My tired old 302 made loads of blow-by but just wouldn't quit! I am also curious...
