transmission swap
Old Jan 18, 2020 | 06:34 PM
Vautomotive17's Avatar
Vautomotive17
Question transmission swap
I have a 2007 Ford f250 4wd with a 6.0 diesel. The automatic transmission is bad. Can I swap in an automatic transmission from a 2008 Ford f250 4wd with a 6.4 diesel?? Thanks in advance for your answers!
Old Jan 18, 2020 | 10:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, you can. The one problem that I know of is that the number of studs from the converter to the flex plate changed. The 6.0L has six studs, the 6.4L has eight studs. Someone else may know if you can swap flex plates to get around this.
Old Jan 18, 2020 | 11:44 PM
SmackDaddy's Avatar
SmackDaddy
https://www.powerstroke.org/forum/6-...ion-6-0-a.html
Old Jan 19, 2020 | 01:04 AM
martinlosangeles's Avatar
martinlosangeles
I have no reverse on my 5R44e
Old Jan 19, 2020 | 03:58 AM
Yahiko's Avatar
Yahiko
Old Jan 19, 2020 | 11:39 AM
thecustommuffler's Avatar
thecustommuffler
Do it! Run a 6 oh converter though. \m/
Old Jan 19, 2020 | 01:24 PM
m-chan68's Avatar
m-chan68
Why are you posting in this thread? A 5R44E transmission is one that was used in a mid 2000s era Ranger equipped with either the four cylinder engine or 3.0L V6 if I recall correctly, completely different animal from the 5R110W referenced by the original poster.
But in answer to your question to regarding your loss of reverse gear, your low-reverse band has likely failed. Those were relatively common to happen on those 5R44E/5R55E transmissions from what I remember.
Old Jan 19, 2020 | 01:26 PM
SmackDaddy's Avatar
SmackDaddy
Please start your own thread in the correct forum, that’s not a transmission for any vehicle with these engines.
Old Jan 19, 2020 | 01:35 PM
Vautomotive17
Thanks for your help
Smirks90
Connecticut Chapter
Apr 28, 2016 08:32 PM
copracr
Oct 12, 2011 07:51 PM
rsalter66
General Diesel Discussion
May 7, 2007 10:22 AM
phantom429
Alberta Chapter
Dec 29, 2002 06:21 PM
