General Diesel Discussion
deisel swap???
Old Apr 25, 2007 | 04:01 PM
rsalter66's Avatar
rsalter66
deisel swap???
i have a 78 bronco what do you all think would be a good deisel for a swap
Old Apr 25, 2007 | 04:43 PM
glasseater's Avatar
glasseater
maybe this should be in the engine swaps section? but to answer your question.. i have no idea but it sounds like a fun idea
Old Apr 25, 2007 | 05:52 PM
Crash687's Avatar
Crash687
Talk to the guys at fordcummings.com and there was also an article for a 6.5l (GM) swap into anything in Diesel Power magazine. http://www.dieselpowermag.com/tech/g...l_engine_swap/
Just some ideas...
Old Apr 26, 2007 | 06:21 AM
fonefiddy's Avatar
fonefiddy
Mel Agnem did it to an 87. It should be very similar. You can contact him over @ Oilburners
http://rides.webshots.com/album/298530888TdzfVW
Old Apr 26, 2007 | 06:24 AM
rsalter66's Avatar
rsalter66
thank you very much !
Old Apr 30, 2007 | 10:14 PM
jimlj's Avatar
jimlj
The 4 cylinder cummins comes to mind.
Old May 2, 2007 | 09:31 PM
OldBlueOvalDude's Avatar
OldBlueOvalDude
Cummins 4BT 3.9l four cylinder turbo diesel is an absolute natural. It's a little scimpy in the hp department at 120 but makes gobs of torque, is extremely fuel efficient, and weighs only about 100 pounds more than a 460. Find an old bread/Frito Lay/FedEx truck with this engine and a T18 or T19 transmission behind it and it is a relatively easy swap. Am in the process of doing this same swap in a 73 F100 and it nearly bolts in. Lack of overdrive in the F100 transmission was the biggest drawback but am currently experimenting with a later model 4sp OD. If you've got 35" or taller tires, direct drive high gear might not be that bad of a problem with the 4BT's 2500 rpm governor speed.
Old May 3, 2007 | 06:00 AM
rsalter66's Avatar
rsalter66
thanks for info , that sounds like exactly what i'm looking for, A TORQUE MONSTER!! , do you think the 78's axel's could still be used ?
Old May 6, 2007 | 07:57 PM
OldBlueOvalDude
Axle should be fine, the Ford 9" is a near perfect balance of strength, light weight and compactness and has been a high performance mainstay in everything from drag racing to prerunners for decades. Long after the "flavor of the month" or expensive hybrid and fabbed axles have lost their luster, the humble 9" will still be handling all of the abuse that a heavy right foot can dish out.
Old May 7, 2007 | 01:44 AM
rsalter66's Avatar
rsalter66
ahmen to that!! ""let the pigion's loose!!""
Old May 7, 2007 | 10:22 AM
origcharger's Avatar
origcharger
Its a nice axle for sure but its the basic design that has made it popular in drag racing. The formula for building one that lives under the most severe abuse is to replace every component made by Ford.
