Sponsored by: Real Truck
Tuner issues, PATS
Old Jan 18, 2020 | 06:29 PM
Kmclane's Avatar
Kmclane
Tuner issues, PATS
Deleted my 6.4l (still allowed where I live) tuned it with an sct x4 with custom tunes for the deletes that I bought second hand. First tune went fine. Checked DTCs and got "output shaft/abs wheel speed correlation, turbo/supercharger performance and lost communication with TCM". Went to change the tunes and then I got a general error code on the tuner and now my truck is bricked. The PATs light is on acting like I'm using a copied key and I it wont start. Pulled the batteries for a good 20 minutes to reset the PCM but still no go. Any help is appreciated. Of course its gotta be ball snapping cold when this happens too
Old Jan 18, 2020 | 07:54 PM
Fefanatic's Avatar
Fefanatic
If you mucked up the pcm programming then it will need to go to dealer for reflash. Not sure there is any other option. Is the security light flashing steady?
Old Jan 18, 2020 | 08:42 PM
Kmclane's Avatar
Kmclane
It flashes for about a minute then goes out
Old Jan 19, 2020 | 09:55 AM
Fefanatic's Avatar
Fefanatic
On the '09 I had the security light continued to flash so you may be having a different issue. The security (sometimes called smart) module is behind the passenger kick panel. It could have gone bad but I would think the programming got trashed with your tuner. It might be possible to call a locksmith to come and reprogram your keys to the truck and that might solve the issue but I am skeptical that it would.
Edit to add: Have you tried to access the module with Forscan? Maybe you can get a better idea of what it happening...
oxt127
Mar 13, 2016 12:26 PM
WatsonR
Jul 17, 2014 09:12 PM
Limestone756
Dec 17, 2009 09:18 AM
cowboyup1988
Jun 10, 2009 08:39 PM
mpinksto
Oct 6, 2003 10:35 PM
