5 speed issues
Old Jan 22, 2020 | 05:00 AM
wahlturfcare's Avatar
wahlturfcare
I went ahead and changed out the slave a couple times. 1st one leaked fluid but had pressure, second wouldn't do anything, so I put the original back and and hardly have any pedal now after bleeding it for a hour. And ideas in how to fix this?
Old Jan 22, 2020 | 06:45 AM
irhunter's Avatar
irhunter
Master cylinder.
Old Jan 22, 2020 | 10:17 AM
wahlturfcare
The original one now will shift but ya have to pump it a few times to get a smooth first gear shift and third wants to grind trying to get into gear.
Master cylinder then?
Old Jan 22, 2020 | 03:59 PM
wahlturfcare
I did change the master cylinder but now, the cap wants to leak fluid down the side. Fluid is full to the line inside, the rubber diaphragm is new, even leaks with the original cap too.
Old Jan 22, 2020 | 06:53 PM
sloopdog1's Avatar
sloopdog1
Did you get a New master cylinder? They are also available as a pre-bled unit,
timemachine455
Apr 9, 2017 06:59 PM
mitchgordon96
Nov 28, 2014 12:34 AM
ampslw
Jun 24, 2012 01:31 PM
SagebrushRR
Jul 25, 2010 07:58 PM
Linc66
Oct 20, 2005 11:14 PM
