My power locks (all doors) suddenly went out this morning. The door switch, key fob and door code all do nothing. However, when I press the pertinent button, there is a clicking sound under the dash. Haven't had time to troubleshoot, much but wanted to see if anyone else has had a similar issue and the culprit. Fuse, relay or some other issue? Is it possible all of my actuators all went out simultaneously?
It's an 02 7.3 and was working fine beforehand, although my rear passenger lock would "stick" and not unlock from time to time.
Does it sound like the door locks are trying to unlock at all or completely dead?
the reason I ask mine had a few week door actuators and one day I went to unlock the doors and all 5 would not work. Ended up taking them apart and fixing them and they work amazing now. Theres a link on how to fix them so just search on here
Reason: Forgot to post something
Is your battery in good shape? Also sometimes when 1 or 2 of the lock actuators go bad they can drag the rest of them down.
Batteries are good. Replaced the alternator and batteries a week ago. Everything has been fine since.
I don't hear anything in or around the locks themselves. Like I said above, the only noise is a click in the dash under the steering wheel. Is it realistic that they all just went out simultaneously? Do they not work independently of each other?
Thanks for your thoughts.[/QUOTE]
Like I said on mine I had 2 weak actuators and one day I came out and all 5 would not lock or unlock but if i listened carefully you could hear them trying to
