Sponsored by: Real Truck
Power Door Locks quit working
Old Jan 25, 2005 | 04:07 PM
jrisebo's Avatar
jrisebo
My power door locks quit working the other day. I checked the fuse and thats fine. I can hear a clicking under the dash, like a relay or something, but I cannot find anything about this. Anyone ever have this happen? I have a F250 SD 7.3L Crew cab.
Thanks
Jim
Old Jan 25, 2005 | 04:17 PM
2000silverbullet's Avatar
2000silverbullet
Sounds like the actuators in the doors have gone bad. Mine did the same thing except it got progressively worse and worse. The door locks would take a few clicks to finally lock/unlock, then it eventually stopped all together.
Old Jan 25, 2005 | 11:54 PM
Gregsd250's Avatar
Gregsd250
does it have a aftermarket alarm system? could possably be the relays that are added
to lock and unlock the doors. mine are located under the dash right above the steering colum next to the fire wall. one is on a pink/green wire and the other is on a pink/yellow wire. one does lock, and the other does unlock. does it work one way but not the other?
Old Jan 26, 2005 | 05:43 AM
jrisebo's Avatar
jrisebo
Door lock
Where are the actuators located for the doors? Is that the clicking that I hear under the dash?
I have no aftermarket alarm. It just stopped working, no intermittent or anything.
Thanks
Jim
Old Jan 26, 2005 | 06:01 AM
morcutt's Avatar
morcutt
Seems odd that both door actuators would die simultaneously. A stupid question, but are you shure you're looking at the right fuse? It sounds more probable that the relays you're hearing aren't getting any power to drive the actuators with.
Old Jan 26, 2005 | 06:21 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome Marc...to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Old Jan 26, 2005 | 06:42 AM
jrisebo's Avatar
jrisebo
Door lock
Yes, I think I am looking at the right fuse, a while back it blew and I had to repalce it, and I also looked it up. I did read somewhere that the cold causes the actuators to bind up...and it was really cold when they quit working. Perhaps I will take the door apart and check them
Old Jan 26, 2005 | 07:05 AM
morcutt's Avatar
morcutt
It's certainly possible that weather has taken a toll, but I'd think that would only be temporary. It's interesting that you stated the fuse blew before. I'm wondering if the contacts on the relays are still good. At any rate, if you pull the door panels, you'll be able to tell pretty quickly if power is making it to the actuators. If not, I'd locate those relays and have a look to 1) make sure that they are getting power to switch to the actuators and 2) make sure that they are successfully switching the power.
Old Jan 26, 2005 | 08:15 AM
DJR 17's Avatar
DJR 17
I have to agree it sounds odd that they all went out at the same time, usually the actuators fail intermittantly.
Old Jan 26, 2005 | 08:56 AM
2000silverbullet
Mine both failed within weeks of one another, but they died a slow and painful death. I actually went a month before they quit all together. At any rate, it sounds like jrisebo is dealing with a different issue since his quit working entirely (not to mention immediately), sounds like a lack of power to the actuators.
morcutt's attack plan is right on (in my book).
