OD light flashing
Old Jan 7, 2020 | 01:13 AM
BAC38's Avatar
BAC38
OD light flashing
So I pulled up a few codes I was hoping someone could shed some light on. I know rhe circuit have no clue where to start looking. I've got Brake cleaner and dielectric grease I was planning on cleaning all sensors. So these are from koeo#23 & #67 and #29 from continuous memory thanks for all help
Old Jan 7, 2020 | 01:49 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
OK code 23 is mostlikely you didn't hold the accelerator pedal to the floor while testing.... code 29 is VSS code 67 is MLPS possibly out of adjustment
Make sure the Mlps is adjusted right.. clear code and don't worry too much.. make sure that connector is clean at the Mlps
Old Jan 7, 2020 | 02:29 AM
BAC38's Avatar
BAC38
Im also getting bad fuel mileage? Any tips. TY
Old Jan 7, 2020 | 08:25 AM
FordTruckfan89's Avatar
FordTruckfan89
If it's out of tune, it'll run like crap and mpg will not be as good.
Old Jan 7, 2020 | 04:41 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
See Post #4 for MLPS testing... Code 67
https://www.ford-trucks.com/forums/2...-the-mlps.html
Here is the Pin Out of the connector so you can make sense of the numbers listed in Post #4
This could be caused by the shift linkage not being adjusted properly when the Reinstalled your Transmission...
Old Jan 12, 2020 | 05:49 AM
Blake Coss's Avatar
Blake Coss
Well you were right they did install a chiller on the outside. I didnt see it until today when i was changing the fuel filter. So I've drove like 100miles since i got it back with the rebuilt transmission. All was good until today I go to leave the shop I drive for i jump out of my truck jump out. I lock the gate get back into the truck put into gear nothing. Same thing as last time i get nothing in all gears and when I try to put it into drive while running it grinds. When its off i can get put into gear. 4x4 selector is not showing upbon dash anymore either. Im gonna make sure i get the whole new rad this time.
Old Jan 12, 2020 | 09:27 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
I wonder if you have a bad t-case, Blake?
Cajun_ford_boy
Oct 5, 2019 08:42 AM
jaagen
Oct 8, 2012 02:57 PM
Budget Racing
Jul 9, 2009 08:57 PM
Rick32
1997 - 2003 F150
Apr 14, 2006 05:21 PM
hedhntr
Apr 10, 2006 06:11 PM
