Anyone know what this part is / why it would be leaking & smoking
does just the hose get replaced or the box part that connect to the valve cover as wel. Ive been able to find the hose replacement part but not the box part
do they normal leak from the hose down onto that or do they leak between the valve cover and bottom of that little box ?? Is it better to run this through an oil catch can ? Seen alot of that as i dont want to reroute it to just dumping it out the tail pipe as ive heard alit of negative about that
This one does not look so good.
https://www.ebay.com/itm/DRIVER-SIDE...MAAOSwN4FdjuvF
But you may want to give these guys a call. In the past they have taken good care of me.
https://dieselredemption.com
hard to tell what is actually leaking the whole hose is covered in oil. No where else has oil but all down that hose from bottom of intake all the way onto valve cover
Casey Hope
09-08-2019 03:43 PM
