Forscan
I need to be educated on Forscan. It seems that Forscan keeps coming up on here more and more even for simple maintenance items such as battery replacement. It's somewhat concerning to me that you need to tell your truck that it has a new battery or that some other piece of maintenance has been done in order for the vehicle to learn / relearn what has been accomplished. Anyway, it's the way of the future and now it's time for me to get on board.
So, I want to purchase a Forscan module and use it with my Galaxy S9.
1. What do I need in order to accomplish this?
2. Best source of supply? I'm reading of knockoff versions on the market.
3. Is it worth the money? I don't intend to modify the truck in any manner from it's original state.
4. If I had to replace a sensor or spark plugs, do I need to tell the truck that this has been done?
Thank you all for your input and yes, I am far behind the times.
I can't speak to the mobile versions of forscan but if I remember the FAQs correctly, only the paid version of mobile (phone) will allow register modifications.
I use this adapter with Windows 10 laptop and it works great. you'll need to download forscan and register on the site to activate a "extended license" that will last a few months. Registering is free and you can use a burner account if you like.
There's 2 methods of modifications - the plain text which spells things out in English and changing register values. Both methods I recommend backing up your as builts before starting so you can revert back.
You don't "need" forscan to do anything maintenance related ,even that battery state will relearn with 8hrs uninterrupted "sleep" as per the manual. You don't need it for sensor swaps.
I don't believe the last gen trucks has as many modifications available as the 15+ some examples of things I've done on my 18:
Enable Bambi mode (lowbeam, highbeam and fog on)
Tones to ICP speaker
Global windows open/close from key fob (press then hold lock rolls windows up, unlock then hold rolls down. Works for drivers and passenger, not rear)
Disable door ajar warning while in park
IPC quick boot (Disables "Ford" animation at startup)
Disable "doo-doo-doo" Start up chimes
Re-enable autolock control in menu (some 2018s shipped with this missing)
Disable backup sensors
Increase lane change flashes to 5
I'd give this a read: https://docs.google.com/document/d/1...it?usp=sharing
Hope this helps, typing between diaper changes on the newborn
Enjoy
Thanks,
Travis
Thanks,
Travis
OBD2 USB Device ELM327 Compatible Interface with HS-CAN/MS-CAN Switch for Forscan FoCCCus Mazda Ford ELMconfig OBD2 Scanner.
It does have the toggle but I could not get the DDM or PDM modules to appear.
Thank you,
I plan to add the Lincoln style autofold mirrors (this should have been factory! or at least an available option), the reverse tilt mirrors, disable the double horn honk and global window open/close mods along with a couple more.
I wouldn't have even considered doing any of this if not for the detailed explanations on here! I can't wait for the adapter to arrive!
I have been reading posts on this thread for a couple days and haven't seen anything that adresses my situation yet, but I apologize if it has been. There is a lot of posts to go through! I have a 2015 Lariat that was originally a Canadian lease truck. I bought it in 2016 with less than 18,000 miles on her. I love this truck! But there is one thing I would also love to change. Every time I start the truck, the digital speedometer defaults to kilometers per hour. Has anyone found a way to change this to miles per hour? This can be changed back and forth by pressing the OK button on the steering wheel, but has to be done every time I start the truck. The dealer swapped the analog display before I bought the truck, so that has the MPH on the outside and the KPH on the inside like other US trucks. When I first bought the truck, all of the display was in French, and I had to pull a fuse to get it to reset so I could change the default language to English, but the digital speedometer still defaults to KPH.
Thanks in advance for any insight.
So I downloaded the latest version of FORScan 2.3.31 on March 22, 2020 with the free 2 month trial, and purchased an OBDLink EX USB cable from Amazon and connected it to my 2017 F-150 XLT.
First thing I did once everything was up and running was attempt a backup of all the "as bulit" modules. It was smooth sailing until I got to the IPC (instrument panel cluster) and approx 30% of the way into that backup I got the "service interrupted" message and couldn't get past that.
I researched the thread and other forums and saw that other people were having the same issue a few years ago with earlier software versions. I have the very latest version and I would expect that previous bugs have been worked out of the software by now.
Anybody have any ideas whats going wrong here? Any help would be much appreciated! Thanks in advance!
