Forscan
Old Feb 3, 2021 | 09:33 AM
  #31
nddragon01's Avatar
nddragon01
Not sure if this is possible, but is there a way to easily reverse the Lincoln style mirror fold in setting? I'm now thinking that I'd like the mirrors to not auto fold and unfold as the truck locks and unlocks, and was wondering if there is a master list somewhere of the "original" code settings. Or is it that the "original" codes are all different for every year / style / trim of truck out there, and there is no way to know what the original codes were without having a saved original file for my truck?
Old Feb 16, 2021 | 04:45 PM
  #32
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Do you have your original AsBuilt file ?
ZooDad
Old Apr 27, 2021 | 10:39 AM
  #33
Ophir1236!'s Avatar
Ophir1236!
8th Gear
Originally Posted by GABAR
Ummm, just purchase a quality scan / diagnostic tool and forget the app.
What tool is that? Ford F250.
Old Apr 27, 2021 | 03:13 PM
  #34
GABAR's Avatar
GABAR
Just do a search online for a good DIY scan / diagnostic tool.
There are plenty of brands out there.
Old Dec 28, 2021 | 02:21 PM
  #35
rssnape's Avatar
rssnape
Forscan Questions
I am new to using Forscan (read but not executed). I have identified some things I would like to do from the spreadsheet posted by Livinitup I think.
Certain things I would like to do if possible but haven't located:
  • Set to "Eco" mode by default at startup.
  • Set transmission fluid pump to "on" during flat tow mode
  • Set radio to "off" by default at startup
If someone can point me in the right direction to find these or where to start looking, that would be great.
Thanks in Advance!
Old Feb 4, 2022 | 08:03 AM
  #36
boater8987's Avatar
boater8987
What tool is recommended for forscan?
Old Feb 4, 2022 | 12:36 PM
  #37
cps's Avatar
cps
There are many obd2 adapters on the market that will work. Make sure it has a HS/MS toggle switch. I have one from BBfly, works fine.
Old Feb 4, 2022 | 12:37 PM
  #38
jake415's Avatar
jake415
https://forscan.org/home.html
Old Jul 20, 2022 | 11:01 AM
  #39
Elitedually's Avatar
Elitedually
4wd Low
2020 Autofold
Hello Im working on a 2020 Raptor it has the button to fold the power mirrors in. Im looking to understand what coding I need to do so that when vehicle is locked from key fob the mirrors fold. this vehicle does not have the option to enable in the dash like my super duty does.
Old Sep 15, 2022 | 11:38 PM
  #40
Shane Aydelott's Avatar
Shane Aydelott
2nd Gear
Forscan on multiple vehicles
Originally Posted by wylecoyote
Does anyone know if this can be used in multiple vehicles. I have a 19 F350 and step dad has a 19 f150. I updated a few things on mine and he wants a few things done also, just wondering if I can use it on his also with the same license agreement.
I modified a few of the settings on my 2018 F150 XLT, then went to my 2017 Edge and modified some of the settings on it. No problems. Of course I backed up both vehicle in separate files.
Old Sep 16, 2022 | 02:21 AM
  #41
Brad Lewis's Avatar
Brad Lewis
Trailering
Yes,you can use FORSCAN with multiple vehicles. For example, I use it with my 2020 F150 and with DW’s 2018 Explorer. As someone else mentioned, just connect to a vehicle and make sure to save files for that specific vehicle.
Old Sep 16, 2022 | 02:36 AM
  #42
Brad Lewis's Avatar
Brad Lewis
Trailering
Originally Posted by scott91370
storage_man nailed it. Without Windows, Forscan is just a tool to look at stuff.
Thats not exactly correct. While it is true FORSCAN Lite (for my iPhone) will not allow programming changes, it does have some “service” and testing capabilities. Two things I have done with the lite version:
  • perform a DPF (diesel particulate filter) operator controlled cleaning on my 2017 F350.
  • repaired a “rear camera misalignment calibration” DTC on my 2020 F150. The lite version has the ability to reset all the computer modules back to OE factory settings which restored the camera settings to work as intended.
So the lite versions have some limited but very useful features that many of us can use.
Old Nov 18, 2022 | 05:49 PM
  #43
Trailblazen's Avatar
Trailblazen
Have had a ODBII MX Bluetooth module for a few years now from my last F150 (2011) just for diag/code reading. Stumbled across this thread, fired up FORScan for the first time and went to work on my new to me loaded 2019 F150 Lariat I got at the end of September just about an hour ago. Enabled stuff I wish my truck had that my wife's 2017 explorer has/my old 2011 had (Lincoln mirrors, see text messages/adjust nav), bambi mode, heated seats on the home screen and 5 blink turn signal just to name a few. Took me longer to wait for the 2 month trial license key to show up in my email than to do all the modifications I wanted to do. Insanely easy as long as you follow the guide and please for the love of god, always do an initial backup of default settings prior to racing into the mods. Anyone who is still on the fence, I just literally did it all in 15-20 minutes to include function testing the changes and I was not worried at all.
Old Dec 4, 2022 | 06:54 PM
  #44
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
NEW! FORScan HELPING HANDS
A Directory of FTE Members Experienced with FORScan who may be willing to help you!
Links to a spreadsheet of FORScan Helping Hands on Google Docs:
Old Dec 4, 2022 | 08:07 PM
  #45
RLXXI's Avatar
RLXXI
It should be noted to use at your own risk conscience as Forscan is a Russian made program.
