99 Expy Rear Diff Question
Old Oct 12, 2003 | 04:55 AM
BigMan69's Avatar
BigMan69
In my owners manual, it says the rear diff is filled with synthetic fluid and should NOT be changed unless it is submersed in water. You guys buy that or should it be changed? If so, when?
Thanks
Old Oct 12, 2003 | 11:30 AM
PaulC's Avatar
PaulC
I've never bought into the lifetime-fill philosophy. Your truck is approximately five years old. That fluid, along with loose metal particles from the manufacturing process and normal wear and tear, has been circulating in the diff for a long time. Even if the lubricating qualities are intact, it's probably contaminated to some extent.
I have changed mine every 30k. A bit **** for the rear diff, but I had an unpleasant experience with ring gear failure on another vehicle, so it buys me peace of mind.
Old Oct 12, 2003 | 11:57 AM
BigMattXXL's Avatar
BigMattXXL
I agree 100% with PaulC - I think the "lifetime fill" idea is that the differential will continue to function (keep in mind I say "function", not "function well") to 200,000 miles on the same fluid. Most people get rid of their cars long before that.
I never liked the idea of all that crap floating around in there.
XXL
Old Oct 12, 2003 | 12:04 PM
BigMattXXL's Avatar
BigMattXXL
Also, when you do change it, don't buy the Ford stuff. Ford wants around $30/Qt for it, whereas you can buy Redline 75w140 GL for $8/Qt, and Redline is super high-end fluid.
XXL
Old Oct 12, 2003 | 04:32 PM
pounder90's Avatar
pounder90
Matt,
Does the Redline fluid require the friction modifier? If so, is it available other than from the dealer? What brand of silicone sealer did you use on the cover? Is it difficult to get a good seal on the cover?
Sorry for all the questions.
Thanks in advance for your response.
Old Oct 12, 2003 | 04:58 PM
BigMattXXL's Avatar
BigMattXXL
Originally posted by pounder90
Matt,
I don't know - the website says it's got a friction mod for LS differentials, but I sent them an email yesterday asking whether or not I should add the Ford stuff. The Ford friction mod is only like $8, so I wouldn't spend too much effort looking for alternate sources. I used black silicon in a pressurized tube - just put it on the cover, let it skin over, stick it on there. Pretty easy.
XXL
bhds1
Escape & Escape Hybrid
20
Jan 26, 2022 03:10 PM
reptar0077
Jun 13, 2016 03:22 PM
Wrecklesswisdom
35
May 19, 2016 09:52 PM
evan1242
Aug 15, 2015 11:33 PM
buttz
1997 - 2003 F150
Jun 15, 2015 04:08 PM
